I know this is linked to an older version of the interface, but is possible to disable editing thumbnail photos on all web interfaces?
We have a workflow to to edit the jpegPhoto attiribute with a high quality photo which is resized for the thumbnail and also pushed to a Cloud IdP.
related to an answer for: thumbnail and jpeg Photo attribute
by (1.2k points)
Unfortunately, there is no possibility to disable the option in the Web Interface settings. To achieve the desired behavior you need to make sure that only corresponding users have the permissions to modify the thumbnailPhoto property of other accounts. Users that do not have the permissions, will not see the option below user pictures.
Permission ThumbnailPhoto
Adaxes Support, Is there a way to disable the Nested Group function of Active Directory in Adaxes. We are using some nested groups in rare cases but our corporate ... or blocking users that manage groups to only added members and not nest groups. Rodney
asked Aug 29, 2013 by rjthompson (80 points)
In past I am able to enable Auto Logon (Windows Integrated Auth) in our Internal Adaxes Server (full server) and in same time Form based auth for DMZ Based web server ... login when internal network but when outside, they should get the auth form for login.
asked Feb 20, 2019 by Brajesh (460 points)
3,362 questions
7,812 comments
545,232 users
