All business rules, custom commands and scheduled tasks executing a specific custom command
The script creates a file containing all business rules, custom commands and scheduled tasks executing the specified custom command. The script can be executed in a custom command or scheduled task.
  • $customCommandID - Specifies the identifier of the custom command to search for. For details on how to get the identifier, see /sdk/HowDoI.GetConfigObjectID/.
  • $csvFilePath - Specifies the path to the file that will contain search results.
$customCommandID = "{9DB88EC3-1241-4AB1-9612-C7C982BAA49F}"
$csvFilePath = "C:\Scripts\Report.csv" # TODO: modify me
function IsActionFound ($actions, $customCommandID)
    foreach ($action in $actions)
        if ($action.Class -ne "adm-CustomCommandAction")
        $customCommandAction = $action.GetAction()
        if ($customCommandAction.CustomCommandId -ne $customCommandID)
        return $True
    return $False
function IsContainsExecuteCommandAction ($configurationObject, $customCommandID)
    for ($i = 0; $i -lt $configurationObject.ConditionedActions.Count; $i++)
        $conditionedActions = $configurationObject.ConditionedActions.GetObject($i)
        if (IsActionFound $conditionedActions.Actions $customCommandID)
            return $True
        elseif (IsActionFound $conditionedActions.ElseActions $customCommandID)
            return $True
            for ($j = 0; $j -lt $conditionedActions.ElseIfConditionedActions.Count; $j++)
                $elseIfConditionedActions = $conditionedActions.ElseIfConditionedActions.GetObject($i)
                if (IsActionFound $elseIfConditionedActions.Actions $customCommandID)
                    return $True
    return $False
$configurationContainersToObjectTypes = @{
    "CustomCommands" = "adm-CustomCommand";
    "BusinessRules" = "adm-BusinessRule";
    "ScheduledTasks" = "adm-ScheduledTask";
$records = New-Object System.Collections.ArrayList
foreach ($item in $configurationContainersToObjectTypes.GetEnumerator())
    # Search configuration objects
    $path = $Context.GetWellKnownContainerPath($item.Key)
    $searcher = $Context.BindToObject($path)
    $criteria = New-AdmCriteria $item.Value
    $searcher.Criteria = $criteria
        # Execute search
        # Search 'Execute Custom Command' action
            $configurationObject = $Context.BindToObjectBySearchResult($searchResult)
            if (IsContainsExecuteCommandAction $configurationObject $customCommandID)
                $record = New-Object PSObject
                $record | Add-Member -MemberType NoteProperty -Name Name -Value $configurationObject.Get("name")
                $record | Add-Member -MemberType NoteProperty -Name Path -Value $configurationObject.AdsPath
                $records.Add($record)
        # Release resources
$records | Export-Csv -Path $csvFilePath -NoTypeInformation
Comments 0
