Remove values for deleted objects from a multi-valued property
Objects can be present in a multi-valued DN syntax property (e.g. Secretary) of another object. If such an object is deleted, the corresponding property value gets to be something like the following:
John Smith DEL:ba5e2568-0a8d-4a06-a9b2-df24b7ba94c2 (company.com\Deleted Objects)
The below script removes such values from the specified property to only keep values for existing objects. It can be executed in a business rule, custom command or scheduled task configured for the object type you need. In the script, the $propertyName variable specifies the LDAP name of the property to update.
$propertyName = "secretary" # TODO: modify me
# Get current property values
    $values = $Context.TargetObject.GetEx($propertyName)
    $Context.LogMessage("The $propertyName property is empty for %fullname%.", "Information")
# Remove records for deleted objects
$newValues = New-Object System.Collections.ArrayList
foreach ($value in $values)
    if($value -notlike "*DEL:*,CN=Deleted Objects,*")
        $newValues.Add($value)
# Update the property
$Context.TargetObject.PutEx("ADS_PROPERTY_UPDATE", $propertyName, @($newValues))
Comments 0
