Generate sequential property values
The script generates sequential property values consisting of a fixed textual part and a sequence number, for example IDDQD-001, IDDQD-002, IDDQD-003 etc.
To generate object names using the script, create a business rule triggered before creating an object. For details, see Validate/Modify User Input Using a Script.
PARAMETERS:
  • $numberProperty - the name of the property of the managed domain that stores the last used number.
  • $domainDN - Specifies the distinguished name (DN) of the domain that will store the last number set. For information on how to get the DN, see https://adaxes.com/sdk/HowDoI.GetDnOfObject/.
  • $propertyName - the name of the property to generate value for.
  • $valueFormat - Specifies how to format the value. For details, see Getting started with the String.Format method.
  • $objectCategory - Specifies the object category for which values are generated, e.g. user or computer.
  • $initialNumber - Specifies the starting number to use if there is no number saved in Adaxes configuration.
  • $maxNumber - Specifies the maximum number that can be assigned.
$numberProperty = "adm-CustomAttributeInt1" # TODO: modify me
$domainDN = "DC=domain,DC=com" # TODO: modify me
$propertyName = "employeeID" # TODO: modify me
$valueFormat = "IDDQD-{0:000}" # TODO: modify me
$objectCategory = "user" # TODO: modify me
$initialNumber = 1 # TODO: modify me
$maxNumber = 999 # TODO: modify me
function IsValueNotUnique($filter)
    $searcher.SizeLimit = 1
    $searcher.VirtualRoot = $True
        return $searchResults.Length -eq 1
        # Release resources
# Get the number stored in domain property.
$domain = $Context.BindToObjectByDN($domainDN)
    $number = [int]($domain.Get($numberProperty))
    $number++
    # Use the initial number
    $number = $initialNumber
# Build value
$uniqueValue = [System.String]::Format($valueFormat, $number)
do
    if ($number -gt [int]$maxNumber)
        $Context.Cancel("Cannot generate a new value for $propertyName because the maximum `
                allowed object number has been reached. Contact your system administrator.")
    $isValueNotUnique =  IsValueNotUnique "(&(objectCategory=$objectCategory)($propertyName=$uniqueValue))"
    if ($isValueNotUnique)
        # If the value is already in use, generate a unique one.
        $number++
while ($isValueNotUnique)
# Update the number in doamin property
$domain.Put($numberProperty, $number)
$domain.SetInfo()
# Update property value.
$Context.SetModifiedPropertyValue($propertyName, $uniqueValue)
Comments 0
