I have a need to run a report on users who haven't logged on in over 90 days. I found your Inactive Users report in the Web Interface, which does exactly what I need, but I haven't been able to figure out how to build a Scheduled Task to make that report run on a regular basis. I then need to take those users and do some tasks on them (disable and move to another OU). Is there a way to do this?
by (50 points)
Currently, it is possible to schedule reports only using PowerShell scripts. In the next major version, we are going to add the possibility to schedule reports using UI.
For an example of a PowerShell script that builds a report and emails it to a certain recipient, see Example 4 under Script Examples. To Schedule such a script, you can use a Scheduled Task that executes the Run a program or PowerShell script action.
Thanks for the info. I've been able to create the scheduled task as you indicated below.
Is there any word on when the next major version will be available with this feature?
We cannot provide any exact dates yet. We are targeting the mid-2016.
I'd like to add a field for "Ticket Number" to pass through so that I can have it run a script post execution to log data to our ticketing system. I ... it may be possible to extend the public class ResetPasswordOptions but that's not really ideal...
asked May 27, 2024 by ZoomGhost (280 points)
Hello, Is there a built in method for checking user accounts that have expired in Azure?
asked Jul 31, 2023 by Homelander90 (370 points)
asked Apr 14, 2023 by mightycabal (1.1k points)
asked Nov 8, 2022 by GronTron (320 points)
We can authenticate if we login to the machine hosting the service but if I have the client installed on my desktop, I can't authenticate with any ... .com/en-us/windows-server/security/credentials-protection-and-management/protected-users-security-group
asked Sep 12, 2022 by mark.it.admin (2.3k points)
550,368 users
