Hello Support,
i've got two questions:
  1. I'd like to integrate the Threema API (https://gateway.threema.ch/de/developer/api) for sending messages instead of sending SMS. Configuration is not a big deal but i also would like to use the Threema ID instead of the mobilenumbers and they contain letters and not only numbers and Adaxes doesn't seem to like that. It returns something like "The mobilenumber "XXXXXX" contains invalid characters". Is there a possibilty to skip the check or to extend the characterset?
  2. Is there a chance to "pre set" the standard front type in the configuartion to a specific front type and size for the exchange automatic reply when using the Adaxes?
Thanks Markus
by (170 points)
Hello Markus,
At what moment do you face the error? Please, provide all the steps you take before the error occurs. Also, please, specify what exactly you did in terms of configuration. Screenshots will be much appreciated. You can post them here or send us at support@adaxes.com.
by (170 points)
The Threema ID is saved in CustomAttributeText8.
When i try to send a "SMS" aka Threema Messages, this happens:
Thanks again Markus
Hello Markus,
Thank you for the provided details. This behaviour is by design and there is no workaround for it. Only digits are allowed in phone numbers for SMS delivery. As a solution, you might be able to send messages using Threema ID via a script. However, that is something you will need to check with their support team.
Hello! I would like to use the utc parameter that is described in value references - date/time formatting (https://www.adaxes.com/help/ValueReferences/). The goal is ... please indicate whiich would be the right way for using the utc switch? Thanks, Fabiano
asked May 3, 2024 by fabiano.santos-agco (20 points)
Hi smart people! I'm using this script: http://www.adaxes.com/script-repository ... t-s423.htm Which works great for sending an email to someone, listing their direct ... body of the email at once would be greatly appreciated! Thanks for any and all replies!
asked Mar 24, 2017 by 3Jake (210 points)
When trying to set "Accept Messages" to "All senders" on distribution group through Adaxes web interface I get error: Adaxes doesn't have any permissions to ... of mentioned role? I tried give it msExchRequireAuthToSendTo permission but that didn't help.
asked Dec 1, 2022 by KIT (1.1k points)
Occasionally we will go over the license user count and have take steps to bring it within compliance. We would like to only see the license violation message in the Admin ... and not in the Help Desk or Self-Service interface. How would we accomplish this?
asked Dec 19, 2017 by juanfperezperez (50 points)
Is a SMS provider required for sending SMS messages? Currently we send SMS alerts via email address, for example number@vtext.com, number@txt.att.net, etc. We store the addresses in a field in AD.
asked Apr 11, 2013 by Kikaida (1.1k points)
