Where i'm actually working, it seems there is an "old dev" Adaxes environnement which was linked to the AD.
The server has been deleted now, but it seems the Windows Integration (for Password Self-Service) is still linked to that old server. Even if i install a fresh client.
Where those parameters came from a GPO i guess ?
by (460 points)
by (460 points)
I found a parameters in the Windows integration menu which allow me to set a priority. This worked fine and now i can see the parameters of my "new" Adaxes.
I don't have any notification in my tray about the enrollment (setted in Windows intégration) and the user get a policy associated.
any idea ?
Hello Alexandre,
Did you install Adaxes Self-Service Client on the computer that you are testing from? The notification will only appear on computers that have the Self-Service Client installed. Also, have you already enrolled for password self-service? The notification will appear only for users who haven't yet enrolled.
by (460 points)
Yes the computer have the client installed and no i don't have enrolled for password yet.
Alexandre,
To help us troubleshooting the issue, can you enable Self-Service Client trace logging and send us the log file? To do this:
  1. Launch Windows Registry Editor. Click Start, Run, type regedit, then click OK.
  2. Locate the following registry key:
    [HKEY_LOCAL_MACHINE\Software\Softerra\Adaxes Self-Service Client]
  3. Right-click the LogLevel entry and select Modify (create the entry if it does not exist).
  4. In the Value data box, type 2 and click OK.
  5. After logging is enabled, Adaxes Self-Service Client will log all events to file adaxeswinlogonextlog.txt located in the System32 subfolder of your Windows folder. Send the file to our support email (support[at]adaxes.com).
by (460 points)
I edited the registry then reboot my computer, the popup finnaly appeared (i had previously reboot the computer after client install).
I will try on another computer to check if it's working correctly.
hello Alexandre,
If everything works fine after reboot, do not forget to disable the logging. For this purpose, set the LogLevel entry to 0.
by (0 points)
What changes did you make in between the reboot and the registry to get it to work? I am still having the same issue.
Hi, I'm trying to fully automate the deployment of Adaxes (using windows DSC ressources). I was able to setup servers with only the front-end features, but cannot ... relevant information in the forum or online about giving the credentials to the installer...
asked Jul 13, 2017 by thomas.laborde (100 points)
If a user is disabled, I would like the following process to be automated: Direct reports of this disabled user (user A) are reassigned to new active user (user B) who ... is sent to User B indicating User As direct reports have been transferred to User B
asked Apr 29, 2022 by Cavolick (80 points)
Hey, i'm trying to install Adaxes one a new server for our multi-server-environment. The new Server is Windows Server 2025, but it always fails with the following ... all? The other server in our environment where Server 2019. Thanks and best regards Markus
asked Feb 12 by roppiffm (170 points)
During installation of the Adaxes in new testing domain hosted in Azure Microsoft Entra Domain Services this error was thrown "Failed to create application partitions on the backend ... this is related to the fact this is not ordinary AD, but Azure hosted.
asked Sep 17, 2024 by KIT (940 points)
Is the further clarification on how to join the Adaxes service to the configuration set during a multi-sever upgrade
asked Nov 16, 2022 by itsupport (20 points)
