Is it possible to send more than 160 characters in a SMS?
If I try sending a SMS with more than 160 characters, I get this error message:
“The message was truncated to 160 characters”
We are using Email to SMS.
by (50 points)
Currently, it is not possible to extend the limit. We have a request to make it configurable in our Product Backlog. We'll add a +1 to that item on your behalf, if you don't mind.
Thank you
Starting from Adaxes 2017.1, you can configure the maximum length of SMS messages. To do this:
  2. Right-click your Adaxes Service and select Properties.
  3. Activate the SMS Settings tab.
  4. Click More options.
You can download the latest build here.
Upgrade Instructions
What's New
Hi Support, I'm trying to use adaxes to send a couple of branded emails with User information such as UPN and First name. I've written some HTML email code but would ... <table class="wrapper" width="100%" cellspacing="0" align=center cellpadding="0">
asked Feb 18, 2020 by richarddewis (260 points)
Hi Forum, Today :) i have 2 questions: 1. is it possible to disable the "Show indirect membership" option in the member of Section of the Webinterface? 2. We regularly ... it better to put this into a different database? Thanks a lot for your help. Cheers
asked May 21, 2015 by esoAdxAdmin (650 points)
Hi, First of all, what a great product! However, I do have some questions, I tried searching for the answers but I couldn't find any relevant information. How do I ... is there an option to change the error message on the login-page? Best regards, Tommi
asked Nov 18, 2013 by labero (20 points)
Hi, I do not find where in the web config file we change this limit. Thanks for your help
asked Jul 28, 2011 by sroux (800 points)
I have taken a look at the below help article for configuring password generation parameters, but I am not sure where to add this as a script in Adaxes admin ... https://www.adaxes.com/help/PasswordGenerationParameters/ Thank you in advance for all the help
asked Jan 11, 2024 by Vish539 (500 points)
3,717 questions
8,592 comments
549,995 users
