We have a need to run a DirSync (Azure AD Connect) delta sync from Adaxes.
Currently, on the DirSync server we have a .ps1 script that is just calling the command to manually run a delta sync.
As part of a custom command in Adaxes, how we can we execute a powershell script residing on a remote server?
by (480 points)
You can do that using PowerShell scripts. See the following page in our script repository for samples: http://www.adaxes.com/script-repository ... 5-s187.htm. To add the script to your Custom Command, use the Run a program or PowerShell script action.
asked Feb 19, 2020 by Martin (170 points)
Hello, I have a sheduled task running. This task checks if a user is a member of a Licensed Office 365 Group with exchange online. If the user does not have an ... the on prem exchange mailbox and the exchange online mailbox? Thanks if you have an idea!
asked Feb 24, 2023 by fabian.p (380 points)
Hello! I've just upgraded our installation of Adaxes to 2014.1, and I'm looking forward to utilising the new features, particularly the O365 Cloud management features. However ... switch (will wait for some feedback), would be greatly welcome. Many thanks, Jay
asked Apr 11, 2014 by jaypaterson (90 points)
I have a few reports that I want to add to a custom command workflow such that the report is executed and exported to a csv in a pre-defined (variable) path. I was ... a script to run the report and export it, but could not locate information on that process.
asked Oct 28, 2024 by aweight (80 points)
I have a scheduled task that runs a custom command that itself has multiple custom commands that run in a specific timed order. I would like the scheduler to run that top level ... , but Command B and C will wait for Command A to finish. Is this possible?
asked Jul 23, 2024 by DA-symplr (120 points)
