Hi again :-)
It seems that Web interafces is very slow for any kind of operation (search, modifiy) when the user is part of several ACL in Adaxes.
It took me some time to consider this issue as i always test with my account which is superadmin, and in that case it's ok.
Is there any special consideration to optimize speed for regular users ? Thery are complaining a lot for the moment and i'm afraid they stop using the tool if nothing is done.
Thanks for your help.
Stephen
by (800 points)
Hello Stephen,
The performance significantly depends on the role assignment type. Do you have any roles assigned over query-based Business Units?
Can you backup your configuration and send it to me? We'll analyze the assignments and advise you how to improve the performance.
by (800 points)
Yes we use query based BU. I can send you the configuration, that's not a problem. Does it make sense in terms of performance to change query based BU (include by query) to container BU (include all children of) ?
Yes, it does.
We just had a lengthy discussion about performance issues related to Security Roles. We came up with a solution on how to significantly improve access control checks. We decided to include the improvements in 2012.1.
Thank you for raising the problem!
Yesterday we released Adaxes 2012.1. In the new version we improved the performance of access control checks made by Adaxes. This has significantly boosted the overall performance of Adaxes Web Interface
I have a report which is basically a query for specific set of users for which I want the last logon attribute (not the last logon timestamp). When I sort the same report ... fine. But the same report in Adaxes web portal the sort is not working the same way.
asked May 23, 2024 by Vish539 (500 points)
Hi Currently we have an Adaxes system set up for our Service Desk staff to log into and manage users / groups etc this is currently assigned by assigning the Service ... there be any limiting factors such as licencing requirements for this? Thanks in advance.
asked Dec 15, 2020 by R_C (70 points)
