Hello we want to renaming a user with changing the userhome directory and the exchange properties.
i adding the code we have:
Import-Module Adaxes
function DoesUserExist($username)
    $obj = Get-AdmUser $username -ErrorAction SilentlyContinue
    return $obj -ne $null
#first test of username
$username = "%firstname:lower,2%%lastname:lower,2%"
$newValuesAMAccountName = $Context.GetModifiedPropertyValue("sAMAccountName")
$newValuemailNickname = $Context.GetModifiedPropertyValue("mailNickname")
#no entry
$Context.LogMessage("Aktueller sAMAccountName = '$newValuesAMAccountName' und MailNickname = '$newValuemailNickname'.", "Information")
#Check whether an object with the same DN already exists.
if ((DoesUserExist $username))
    #second test
    $username = "%firstname:lower,2%%lastname:lower,3%"
        #third test
        $username = "%firstname:lower,3%%lastname:lower,3%"
           #it should work before, if not get this message
           $Context.LogMessage("Bitte Namenskürzel prüfen.", "Information")
            #$Context.LogMessage("Der sAMAccountName wurde auf '$username' gesetzt.", "Information")
            $newValuesAMAccountName = $username
            $newValuemailNickname = $username
#got the right entries
$Context.LogMessage("Neuer sAMAccountName = '$newValuesAMAccountName' und MailNickname = '$newValuemailNickname'.", "Information")
$Context.SetModifiedPropertyValue("sAMAccountName", $newValuesAMAccountName)
$Context.SetModifiedPropertyValue("mailNickname", $newValuemailNickname)
$newValue = $username
$divValue = "newObj"
#userhome path
$Path = "\\netplans.de\npdfs2\userhome\"
Rename-Item -Path $Path$divValue -NewName $Path$newValue
$Context.LogMessage("New Full Path is $Path$newValue.", "Information")
after this Skript we try to set the new sAMAccountName for: image.png
But the sAMAccountName and Alias for Mail, is ever the old entry. How can we use the new sAMAccountName?
by (150 points)
by (16.6k points)
For troubleshooting purposes, please, clarify where the provided script is executed. Is it executed in a business rule triggering Before renaming a user? Additionally, please, provide us with a screenshot of the After renaming a user business rule in a higher resolution as currently, it is not readable. You can post the screenshot here, or send it to us at support@adaxes.com.
by (150 points)
It is executed in a business rule triggering After renaming a user. In formular we only change the fullname, firstname and lastname.
Then we executed in a business rule triggering Before renaming a user.
Run little script: $oldValue= $Context.TargetObject.Get("sAMAccountName") $divValue="newObj" $Path = "\netplans.de\npdfs2\userhome\"
Rename-Item -Path $Path$oldValue -NewName $Path$divValue
$Context.LogMessage("Full Path is $Path$divValue.", "Information")
and after that we have the script which is triggering after renaming a user, i send at first.
But the sAMAccountName is ever the old sAMAccountName, i dont know why.
Hope you can understood.
by (16.6k points)
Thank you for clarifying. The GetModifiedPropertyValue and SetModifiedPropertyValue methods can only be used in scripts executed in business rules that trigger Before certain operations (e.g. Before renaming a user, Before creating a user, etc.). In your case, to achieve the desired, you need to execute the script you provided in the original post in the business rule that triggers Before renaming a user.
When a script is executed in a business rule triggering After an operation (e.g. After renaming a user), to get property values you need to use the Get method. To update a property value, use the Put method. After setting a property value, you need to save the changes using the SetInfo method. Additionally, pay attention that all value references used in actions, conditions and scripts resolve before the conditions are checked and the actions are executed. It means that if you update a certain property in an action (it can be a built-in action or a script) and you need to update other properties based on the modified property value, it must be done in a script without using value references.
by (150 points)
Now i have update the script with using GET, PUT and SetInfo(, it looks good. But the exchange Properties which i set afterwards are not correct. Here i got the old sAMAccountname.
$ns = New-Object("Softerra.Adaxes.Adsi.AdmNamespace")
$service = $ns.GetServiceDirectly("npadx1.netplans.de")
# Bind to object
$userDN = "%distinguishedName%"
$user = $service.OpenObject("Adaxes://$userDN", $null, $null, 0)
# Get single-valued property
$oldValue = $user.Get("sAMAccountName")
$user.Put("sAMAccountName", $username)
$newValue = $user.Get("sAMAccountName")
#Ausgabe im Skript
$Context.LogMessage("Alter sAMAccountName: '$oldValue'  Neuer sAMAccountName: '$newValue' ", "Information")
$user.SetInfo()
# Pfad zum Ordner festlegen
Rename-Item -Path $Path$divValue -NewName $Path$username
Alias is aafr, which is the old sAMAccountname. Do you have an idea what goes wrong?
by (16.6k points)
As we mentioned in our previous reply, in your case, the best way to achieve the desired is to execute the original script you provided in a business rule that triggers Before renaming a user. Did you try this approach?
Pay attention that all value references used in actions, conditions and scripts resolve before the conditions are checked and the actions are executed. It means that if you update a certain property in an action (it can be a built-in action or a script) and you need to update other properties based on the modified property value, it must be done in a script without using value references.
by (150 points)
Hello
=> Now I've tried it and it works, thank you. It can be so simple.
asked Oct 24, 2022 by mightycabal (1.2k points)
asked Feb 1, 2024 by Lewis (40 points)
Is the further clarification on how to join the Adaxes service to the configuration set during a multi-sever upgrade
asked Nov 16, 2022 by itsupport (20 points)
