When I run a "Create Exchange mailbox" action against an existing AD User (which adaxes has no problem adding to groups prior to the Create Exchange mailbox action) I receive the following error:
Object 'Adaxes://mp-admanage.wfhf1.hewlett.org:27586/<GUID=cbcaf62b-5931-4af3-9c02-227824b84e7a>' does not exist.
Further details from the event log:
Softerra.Adaxes.CommandPipeline.CommandProcessingException: The following command threw an exception while being executed: Create Exchange mailbox for 'Barney Rubble (wfhf1.hewlett.org\Office Users)' (Alias: 'brubble', Mailbox Store: ). ---> Softerra.Adaxes.Adsi.DirectoryComException (0x80072030): Object 'Adaxes://mp-admanage.wfhf1.hewlett.org:27586/<GUID=cbcaf62b-5931-4af3-9c02-227824b84e7a>' does not exist.
at #qj.#0j.#Gtb(DirectoryException directoryException, #8j resultBuilder)
at #qj.#0j.#rsb(#8j resultBuilder)
at #qj.#uj.#nsb()
at #qj.#9j.#5tb()
at #qj.#9j.MoveNext()
at Softerra.Adaxes.Adsi.Search.DirectorySearcher.#i.#Ej.MoveNext()
at #F.#bp.#vMb(AdsPath adsPath, ClientContext clientContext, Boolean pipelined, String[] requestedAttributes)
at #F.#bp.#oMb(AdsPath bindPath, ClientContext clientContext, Boolean pipelined, String[] requestedAttributes)
at Softerra.Adaxes.Adsi.AdmObjectBinder.BindToObject(AdsPath adsPath, ClientContext clientContext, Boolean pipelined, String[] requiredAttributes)
at Softerra.Adaxes.Adsi.AdmObjectBinder.BindToObject(Guid guid, ClientContext clientContext, Boolean pipelined, String[] requiredAttributes)
at Softerra.Adaxes.CommandPipeline.Actions.ExchangeTaskAction.get_MailboxStorageDatabase()
at Softerra.Adaxes.CommandPipeline.Actions.ExchangeTaskAction.CreateMailbox(IAdmTop targetObject)
at Softerra.Adaxes.CommandPipeline.Actions.ExchangeTaskAction.ExecuteAction(IAdmTop targetObject)
at Softerra.Adaxes.CommandPipeline.Actions.ActionBase.Execute(IAdmTop targetObjectArg)
at Softerra.Adaxes.CommandPipeline.Actions.ActionBase.Execute(ICommand command)
I've already restarted the adaxes service, rebooted, and created a new test user.
Help!
by (60 points)
Hello Byron,
According to the log record, you are executing a Custom Command to create the mailbox. For troubleshooting purposes, could you check whether a correct mailbox storage is selected in the action settings? To do so:
  2. Navigate to Configuration\Custom Commands and select the command.
  3. In the Result Pane, double-click the Create Exchange mailbox action.
  4. Check the mailboxes selected in the Allowed mailbox stores.
by (60 points)
See attachment.
Ours looks slightly different. We're doing this on a hybrid server named MP-EXCH365 to a "Shared and Service Accounts" MB DB.
by (60 points)
Hello again. Speaking with support via chat I was adviced to try to deselect the mailbox database and then re-select it, followed by saving. This resolved our issue. (Basically un-check the selection, then re-select it/check it, and then click save)
Thanks a million
Hi As our initial Adaxes implementation was rushed, I'm re-engineering it so that it fits our work model. We are currently split between on premise and o365 ... changed somewhere to allow mailbox creation after the user account has been moved? Thanks Matt
asked Nov 14, 2017 by chappers77 (2.0k points)
Hello, I can not give the user right to create mailbox exchange I have the following message: The 'Microsoft Exchange (domaine.local\Configuration\Services)' ... (Adaxes\Adaxes Configuration\Configuration Objects\Managed Domains)' object does not exist.
asked May 22, 2012 by mmichard (360 points)
This is from within a custom task. Account has proper RBAC permissions and I can do this from a normal powershell window.
asked Mar 26 by ZoomGhost (360 points)
