Hello Support
We are looking to integrate Adaxes with the HR SQL data warehouse. We found the http://www.adaxes.com/script-repository ... e-s249.htm and have some questions as to how it will work.
Our thoughts are that we will have the SQL database compare yesterday's SQL table to today's and that way we only make changes to the accounts that have changed instead of having to "touch" every account. Please let us know if this is acceptable and recommended method.
We are thinking that we will drive the creation, modification and deprovision of accounts all during the same time. Is this the recommended process? This way we believe we can run it once during the night and make all changes at once.
Thank you
for all your continued support
Jay
by (3.2k points)
Hello Jay,
It is an acceptable approach and can be achieved using PowerShell scripts.
We recommend separating the processes as it can take long time to execute the script.
asked Feb 1, 2024 by Lewis (40 points)
We are currently connecting to SQL 2019 and our DBAs would like to verify SQL 2022 is supported prior to migrating.
asked Jul 15, 2025 by tjackson111 (110 points)
Our SQL DBAs are working to move most/all our SQL connections to SSL. They have asked if Adaxes can support this.
asked Feb 22, 2021 by ggallaway (300 points)
Dear Adaxes team, Please confirm if Adaxes 2019.1 support SQL server 2017 for logging database. Also suggest Adaxes steps to perform if we are migrating our logging database from SQL server 2012 to SQL server 2017
asked Apr 16, 2020 by kushal.gaurav (20 points)
Hi! I'm wanting to perform the retirement of the last Exchange server in an installation, but I need to adjust the SOA (Start of Authority) of ... and contacts. Does Adaxes understand the "onPremisesSyncBehavior/isCloudManaged" change on the onprem objects?
asked 1 day ago by DWNRRH (20 points)
