Hi so if I have the web-interface setup on my internal server where I did the full install but I also have setup a RODC in DMZ how can I "merge" so that the URLS given are for the one in the DMZ vs internal. I have noticed that for example I can have a user manually go to the External one with the DMZ/Public facing IP but I can't seem to get the offline/unlock that shows up to link and show/work for the web server on the DMZ
by (60 points)
Unfortunately, there is no functionality in Adaxes for manipulating URLs. It can only be done in IIS. However, it looks like the only option in your case is to use a load balancer that will forward users to the correct URL.
I am trialing out the product and having some trouble/challenges with the documentation and my setup for External Web access. I will admit even after searching the webs and speaking ... I need like F5 or something I read in the setup. Thank you for your time
asked Nov 4, 2024 by ckelley (60 points)
Hello, The upgrade process is, given my knowlegde, still requiring to uninstall and reinstall the product, importing back then the configuration. I had troubles with that process ... to have a patching process a little bit more easier to apply. Thanks Stephen
asked Feb 18, 2012 by sroux (800 points)
We recently added another domain to our environment, when we use the script to create users from a CSV file they are all being created in the first domain instead of the ... password for user '$displayName'. Error: " + $_.Exception.Message, "Warning") } }
asked Nov 1, 2017 by willy-wally (3.2k points)
Hi, We are currently still running an older version of Adaxes (2014.1) and having an issue with our 2nd server of Adaxes that is in our DMZ. I would like to resolve this ... done to the environment. I am wondering if I can get any assistance on this. Thanks,
asked Jun 6, 2017 by Kobe46 (390 points)
I've got a few questions regarding the setup for the web interface and admin console in the DMZ found here. If we don't want the Admin Console accessible outside the network ... users also hit the RODC in the DMZ or would they use the internal DCs? Thanks!
asked May 5, 2020 by scoutcor (180 points)
