Is it possible or are there plans to allow the grid view to change based on object time? For example, I would like to display Name, Job Title, Department and Manager when the user is selecting from a list of accounts, but then show name and description only if they are selecting from a list of groups.
by (420 points)
No, there is no such possibility.
Hi, In our environment the CN (Name) for a user in AD is randomly generated to ensure uniqueness as everything uses UPN or Display Name for identification. Is it possible to hide ... not in the list? If not, can I change the column heading to Unique ID? Thanks
asked Oct 8, 2014 by dazbo (390 points)
I am looking for a way to view the exact reason why someone would see the error below when accessing the web interface. It would be helpful to see this in a log ... "user attempted to access Web Interface section A, but is lacking the permission XYZ..."
asked Aug 6 by apruitt (550 points)
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8, 2024 by Handernye (120 points)
Hello, I am not getting email responses from support because of a technical problem. In the meantime, I figured for I would post here. I am using the new heldesk web ... how the helpdesk interface is configured and what the user's screen looks like: Thanks.
asked Jul 20, 2018 by Jasonmh (540 points)
I'm testing the latest version. When I remove the domain user security assignment, create a new security role that is identical, but limits the assignment to a ... triggers the change between tree and table view for the Active Directory Location selector?
asked Dec 29, 2011 by mpaul (360 points)
