hello,
I need to create a Custom commands so that help desk can add or remove entries in the "userWorkstations" (Logon Workstations) attribut of a user.
Is there a simple way to do it with Adaxes?
Thanks in advance!
by (1.1k points)
by (1.1k points)
I am almost done but my code only set one workstation, it erase the others one listed in the text file.
#$ImportedWorkstations = Import-Csv -Delimiter ";" -Path $csvFilePath
 foreach($line in Get-Content $csvFilePath) {
    Set-admUser -Identity %cn% -LogonWorkstations $line
    $Context.LogMessage("$line", "Information")
I believe there is somethings to do with array @?
by (1.1k points)
Finally I did somethings like that :
$ComputerList=Get-Content $csvFilePath
Set-admUser -Identity %cn% -Replace @{LogonWorkstations=$ComputerList}
So the helpdesk need to create a texte file conatining workstations before running the script.
is there a way for the heldesk to use a custom form in the web interface so he can search and select worksations directly in AD?
Yes, it is possible. The solution will include a Home Page Action and a Business Rule. The action will contain a DN syntax property (e.g. See Also) that will allow selecting the computers that will be added to the list of workstations for the user. The Business Rule will trigger After Updating a User and execute a PowerShell script that will update the userWorkatations property with the computers specified in the See Also property of the user. The script will be executed only if the See Also property changes.
i. Creating the Home Page Action
  3. Click Add and select Modify User action.
  4. On step 2 of the wizard, define the conditions for selecting the user to be modified and click Next.
  5. Select Use customized form and click Customize Form.
  6. Delete all the sections except for one (e.g. General).
  7. Delete all the properties from the section and click Add below Section fields.
  8. Double-click the See Also property.
  9. Select Show only the following object types.
  10. Select only the Computers checkbox.
  11. Click OK twice and finish creating the Home Page Action.
ii. Creating the Business Rule triggering After Updating a User
  4. Select After Updating a User and click Next.
  5. Click Add Action.
  6. Select Run a program or a PowerShell script.
  7. Enter a short description and paste the script below into the Script field.
     $attributeName = "SeeAlso" # TODO: modify me
     function UpdateWorkStations ($userWorkStationsString)
         # Update user WorkStations
         $Context.TargetObject.Put("userWorkstations", $userWorkStationsString)
         $computerDNs = $Context.TargetObject.GetEx($attributeName)
         UpdateWorkStations $NULL
     $userWorkStations = New-Object "System.Collections.ArrayList"
     foreach ($dn in $computerDNs)
         $computer = $Context.BindToObjectByDN($dn)
         $netBIOSName = $computer.Get("sAMAccountName").TrimEnd("`$")
         [void]$userWorkStations.Add($netBIOSName)
     $userWorkStationsString = [System.String]::Join(",", $userWorkStations.ToArray())
     UpdateWorkStations $userWorkStationsString
  8. Click OK.
  9. Right-click the action you have created and click Add Condition.
  10. Select If changed.
  11. Select If See Also has changed and click OK.
  12. Click Next and finish creating the Business Rule. You should have something like the following:
For information on how to change property display names, have a look at the following help article: https://www.adaxes.com/help/?HowDoI.Man ... Names.html.
by (1.1k points)
Woah great., I will test it.
Thank you.
Hello, I need a way to populate with a schedule task "userWorkstations" with a list of computer objects located under a specific OU. The process must not relpace values already in "userWorkstations" attribute. Thanks, Mic
asked Jan 26, 2022 by zemitch (200 points)
Please sdvise if Adaxes is capable of managing file folder security aa Microsoft LDA?
asked Oct 22, 2025 by hhsmith (180 points)
Due to security restrictions we are planning to deploy: One Adaxes Server per customer with dedicated isolated forest Could you please clarify what is best way to license Adaxes ... server or is there any way to license Adaxes server in a centralized way
asked Jul 15, 2024 by VBahubali (40 points)
Hi all Primary objective is to manage cloud only group membership but in a future include cloud only accounts. I've registered a Azure domain which is managed by ... /www.adaxes.com/questions/12293/add-to-365-group-automation-for-new-account-creations Thanks
asked May 31, 2024 by MinorDruid (20 points)
In our company we have rules, if the function is equal to, for example, HR, then the user is added to those groups. Now we have users who work 20% HR and 30% accounting ... you have any ideas on how to handle duplicate, triple, etc. functions? Thank you a lot
asked Dec 5, 2023 by DRiVSSi (360 points)
