I have been working on a way that will allow us to provision accounts and enable them automatically on their specified start date. I'm using an extensionAttribute to write the date during account creation and then running a separate scheduled task to run a script that checks the current date vs their extensionAttribute date. The script runs in seconds when I run it from the powershell window, but the scheduled task runs indefinitely and is not activating accounts.
Any idea why the script isn't working when ran through Adaxes? (The service account running the script is a domain admin)
 Import-Module Adaxes
 $Date = Get-Date -format MM/dd/yy
 $DisabledUsers = Get-ADmUser -Filter {enabled -ne $True -AND extensionAttribute2 -le $Date} -Properties extensionAttribute2
 Foreach ($DisabledUser in $DisabledUsers)
  Set-ADmUser $DisabledUser -Enabled $True -Clear "extensionAttribute2"
 Exit
Thanks,
by (100 points)
Hello Jo,
The issue occurs because extensionAttribute2 is a String property, while you need a date one. We recommend using one of Adaxes custom Date attributes, for example CustomAttributeDate1.
Hi, I'm currently facing a problem where I want to set up a powershell script that should report all accounts (enabled, disabled, expired) matching a specific employeeType ... something else, just the plain Info Can you help me with this? kind regards Ingemar
asked Sep 4, 2015 by ijacob (960 points)
I am having an issue running a powershell script through Adaxes. I am trying to have this run as a business rule when ... $optoffice.DisabledServicePlans = "ONEDRIVESTANDARD" Set-MsolUserLicense -UserPrincipalName %userPrincipalName% -LicenseOptions $optOffice
asked Mar 2, 2015 by malsobrook (50 points)
Adaxes is set up to manage two forests. The server that Adaxes is running on is a member of the main corporate forest and we added the other untrusted forest (single ... -add @{info=$grouplist} } $Context.LogMessage("Removed from all groups", "Information")
asked Dec 31, 2012 by jiambor (1.2k points)
asked Sep 5, 2024 by emeisner (210 points)
I have a need to have a remote server run Adaxes PowerShell commands, but I keep getting "No Adaxes services found on ." I've tried targeting the Adaxes server with ... command with -AdaxesService localhost, it works fine. How do I get it to work remotely?
asked Jul 16, 2024 by jmatthews (270 points)
