In the Adaxes web interface configuratior, you can set up custom actions, and adjust the object selector.
I am able to set Object Selection to "Objects selected by user," and add custom criteria to only show objects whose Email field contains the initiator's email. Only objects that meet that criteria are shown and they can only pick that object.
This is working great, however I'd prefer using the "Specific" object bubble, so that instead of picking the object, it automatically shows up. Is there a way to add criteria to the "Specific Object" or another way to enter this? In the red square was the format I am looking for to calculate the value:
I hope this question makes sense. Please let me know if there's anything I can clarify.
by (530 points)
Unfortunately, there is no such possibility. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
Is there a way to change the icons for actions that you've put on the home page actions? I know that if I use a custom command and I've set the icon it will use ... Right now all of them use the blue box with a right pointing arrow for their icon. Thanks!
asked Jan 22, 2013 by bemho (520 points)
I have Search configured for one of our web interfaces. One of the fields that can be searched is a custom attribute admCustomAttributeText4 (with a friendly name of ... are definitely some accounts with that attribute populated. Is this behaving as designed?
asked Sep 19, 2018 by sandramnc (870 points)
asked Jan 20, 2020 by KIT (1.1k points)
