I'm making use of a TextMultiValue property, but I'm frequently getting 2 errors when I execute $Context.TargetObject.GetEx("Adm-CustomAttributeMultiValue2"). These actions are taking place on a user, the user can only execute the action on themselves but I'm always seeing the following to errors:
  • Exception calling "GetEx" with "1" argument(s): "The 'Adm-CustomAttributeTextMultiValue2' property cannot be found in the cache." Stack trace: at , : line 34
  • Cannot write to a closed TextWriter.
Line causing the issue:
$IPs = $Context.TargetObject.GetEx("Adm-CustomAttributeTextMultiValue2")
I'm seeing "Cannot write to a closed TextWriter" other times also, can I get any insight on what would cause that?
by (300 points)
Hello Jake,
The error occurs because the property is empty for the target object. To avoid such errors, you need to use try ... catch for getting property values.
For troubleshooting purposes, could you provide the full script you are using?
by (300 points)
Strange - this is a value I'm setting as part of the update to the user's AD account. Currently my script runs "Before updating a user" is that related to why it isn't available? It seems like sometimes this part works and sometimes it doesn't.
I don't always see this but I'll send you the code via direct message.
Hello Jake,
Could you post here or send us (support[at]adaxes.com) a screenshot of the Business Rule configuration?
We provided an update to your script. Give it a try.
Is there a way to configure a Custom Command parameter to accept multiple values so I can then add them to a multi value attribute such as adm-CustomAttributeObjectMultiValue1 ... in my specific case I'm looking to use a directory object picker parameter
asked Nov 27, 2024 by AM (50 points)
Hi all, we switched from an exchange hybrid model to online only. So we turned off our on-prem exchange server. After some tries we faced the following problem: After ... Will Adaxes recognize that there is no on-prem anymore? Thank you for helping us!
asked Nov 16, 2022 by robin.christmann (160 points)
I edited a custom attribute in Adaxes, and manually entered the value for each Org Unit. When I attemp to get that property in Adaxes, it gives me an empty value. I'm sure ... ." You can see at the bottom of the image below that this value does contain data
asked Jan 3 by apruitt (560 points)
asked Jan 29, 2025 by AvenuesRecovery (110 points)
