I'm trying to rearchitect my Business Units, and I'd like to see if I can export the rules on the current business units in a simple format so I can reorganize them and create new ones. Or at least get the rules and go from there.
by (150 points)
by (16.8k points)
Unfortunately, there is no simple and reliable way to export business unit membership rules in a human-readable format. However, it is possible to retrieve the rules using a PowerShell script. Unfortunately, there are no such scripts in our repository. If you decide to try writing your own script, the following SDK article should be helpful: https://www.adaxes.com/sdk/ManagingBusinessUnits.
by (2.7k points)
had the same issue a while ago and created this to export them into JSON and then create HTML overview
Can not paste it directly, as I hit the 35k char limit :D
Script can be found here: https://privatebin.net/?37b7b643171217ab#9uLcsNSR3hM4EkCf9wTVaSizjTn9MVH7ALi5dD4crQf6
When setting up a rule based group, GMSA objects are not visible. Is there a setting or view I need to add to make these availabe to rule based groups, or is it simply not an option?
asked Sep 16, 2024 by ajmilic (150 points)
During the creation of a new user I want to be able to select the job title from a drop-down list which populates different values based on which Department is selected. Is there a way to achieve this? Thanks. Dario.
asked Oct 2, 2020 by winstonsmith (40 points)
We are working with an HR package that will send us a CSV file every 4 hours with a list of users that need to be created, modified or deleted from our environment. The CSV ... change, etc.) Is there a script that can manage all of that on a scheduled basis?
asked Sep 2, 2020 by RayBilyk (310 points)
I'm trying to setup SelfService group management. We have multiple Forests. Because of the Forests we can't add users from a different forest to the ManagedBy. We can add a local ... end up getting all the groups a user is a memberof or nothing at all. :)
asked Jun 23, 2021 by ComputerHabit (810 points)
