Hello all,
I encounter an issue on Adaxes 2013.1 when creating a new custom command to create a user mailbox.
When I choose all my mbx stores (in order to let adaxes select it by turn) and then try to save I get the following error :
"An error occurred while saving the Custome Command. The specified value already exists."
When I specify only one mbx store, it works fine.
Thanks for your help
Regards
by (740 points)
What version of Adaxes are you using? Also, take a closer look at the list of available storages. Do you have any storages that would be listed twice?
There's a similar well-known issue in Adaxes that will be fixed soon.
by (740 points)
Thanks for your answer. I 'm in Adaxes 2013.1 and after another check I find storage listed twice in the list.
Regards
The issue will be fixed in the nearest release. To quickly workaround it until the new release available, in the list of available mailbox stores, for all storages that are listed twice, uncheck one of the items that represent the mailbox store. So that there would be only one checked checkbox for each mailbox store. This should resolve the issue.
by (740 points)
I applied this workaround.
Thanks for your help and your time
regards
Yesterday, we released Adaxes 2013.2 that contains a fix for the issue. Now, mailbox databases are not duplicated in the list of available stores. You can download Adaxes 2013.2 here.
Upgrade Instructions.
We have a custom date attribute that has stopped working correctly, it is set for indicating a new user's start date in an account creation form. This is then used to generate a ... the date is the wrong way round, the server is set as a UK date/time format.
asked Mar 9, 2023 by mashworth (80 points)
Hi, I have a custom attribute for new hire start date with the following configuration : When i retrieve the attribute it is always returned as the day before, as an ... but would like to understand what is going on here, any input would be appreciated.
asked Sep 13, 2019 by digimortal (240 points)
When someone is using a Custom Command, can you detect (WIth PowerShell as Action) "who initiated" the Custom Command? I found that you can use e.g.: adm- ... that are available or are only the %Adm-InitiatorFullname%; ...EMail; ...Dn available?
asked May 12 by LorenzR (40 points)
Hi team, we have a basic approval setup for a specific group I would like to bypass this, in case a specific custom command is executed and trying to add a member to this group ... ? I tried to play around with "If the initiator is xxx" but had no success yet.
asked Apr 10, 2025 by wintec01 (2.5k points)
