How can I make the last name capitalized?
I want a property pattern to generate the full name from the first name and last name. I want these properties to start with Capitalized letters, but in the generated full name, last name to be all upper case.
For example, if users first name if John, and last name is Doe, I want his full name to be generated like John DOE.
by (180 points)
To modify the case of the value inserted by a value reference, you need to use the following parameters: lower|upper. To generate the full name with the last name in the upper case, specify the following value: %firstname% %lastname:upper%.
For more details, see Value Reference Format.
by (180 points)
Thanks, it works! I should have read the manual first.
I'm troubleshooting a weird issue with the "Create User" form and the business rules behind it. The error that's being returned is that the "Company" property doesn't ... a hard time understanding why this one value would fail. Thoughts? Thank you, -Todd
asked Jul 10, 2023 by TAE (70 points)
Dear support, Property patterns for date are currently barely usable. You can define that the value must be: - One of the following values only - Must not contains the ... but it would look cleaner if the property pattern could handle that natively. Cheers !
asked Mar 8, 2019 by Pierre (750 points)
Dear support, I would like to make sure that the account expiration date for an account is between today & 3 months from now. In the property pattern I am able to define a ... you don't need to provide that to me, it is just a feature request :-) Thanks
asked Jul 30, 2015 by Pierre (750 points)
