Is it possible to add additional fonts to the Automatic replies? We have a standard font (Calibri) that we use for our emails, which is not available in the list of fonts.
by (730 points)
The font wasn't available in our previous versions, but starting from 2013.2 (scheduled for tomorrow) you will be able to select Calibri in Automatic Replies.
by (730 points)
Wow, thanks, talk about timing..
Will we also be able to use HTML content without creating separate templates?
Can you describe what you mean in more detail? We are not quite clear on this.
by (730 points)
I mean like insert images, header, footer etc., just like a web page, with the placeholders for Adaxes properties/values.
I believe we need to use PowerShell to do this right now. I'm sorry if this feature is already available and I missed it.
Currently you can insert placeholders for object properties.
by (730 points)
So, if we want to include a header and/or footer image we still need to use a html template and PowerShell to accomplish it?
Can you please give me the link that describes using html templates? I remember reading this some time ago, but can't find it now.
We are not sure whether it will be possible to embed pictures in the auto-reply messages, but at least it is definitely possible to include images hosted on some web site using the HTML img tag (something like image"/>). Our script guys can investigate this for you and find a viable solution. However, they are very loaded with tasks for the new release and cannot proceed to the task immediately. Can you wait till the next week?
by (730 points)
Thank you, no problem. That would be awesome.
OK, we've assigned the task to our script guys and will update this forum topic as soon as they come up with something.
Adaxes 2013.2 is finally available. Now, you can use the Calibri font in Automatic Replies. You can download it here.
Upgrade Instructions.
Hello, We are looking to get our standard users to have permissions to edit their out of office (automatic replies) in the self-service portal. We have setup the settings ... users only see the below How do we make the exchange properties visible to the user?
asked Feb 3, 2022 by JoeG (40 points)
Hi Team I need some assitance with creating a report to pull from exchange online all user mailboxes that have automatic replies enabled. I have been attempting to use ... Where-Object { $_.AutoReplyState -ne "Disabled" } | Select Identity, StartTime, EndTime
asked Aug 25, 2021 by Richard_NRL (90 points)
Hi, We are getting intermittent problems with 2 exchange powershell commands. All the over commands work fine [08/07/2014 19:45:54] Get-CalendarProcessing -Identity "CN=46010248, ... this? I've tried running the command on the mdcexch5r and there is no error.
asked Aug 7, 2014 by darryl82 (40 points)
I have added a business unit to the contents section of the homepage, but only the usernames are displayed. How can I show more columns?
asked Jul 21, 2022 by DA-symplr (120 points)
