Is there a way to enable custom commands for one domain ONLY? So that the command doesnt even show when viewing a user in a domain that doesnt have that custom command?
Example:
You have one webinterface for all your managed domains
Users in domain A is on a Citrix plattform, and you should be able to run Citrix Custom Commands against users in this domain. You should also just see the Citrix commands.
Users in domain B is on a VDI plattform, and you should be able to run VDI Custom Commands against users in this domain, and NOT Citrix Custom Commands. You should also just see the VDI commands.
by (960 points)
Yes, you can do this with the help of Security Roles. You can create a set of Security Roles, one Role per 'environment'. In that Role, you need to add the Deny permission to execute all Custom Commands that belong to a particular 'environment', assign the Role to Authenticated Users, and include the domains where the Command must not be executed in the Assignment Scope of the Role. So, for example, for Citrix Custom Commands, you need to create a Security Role that denies the right to execute all Citrix commands, and include all domains that are not running the Citrix platform in the Assignment Scope.
To create such a Security Role:
  2. On the 2nd step of the Create Security Role wizard, click Add.
  3. Select the object type on which the Custom Commands can be executed (e.g. User).
  4. In the General permissions section, check the necessary Custom Commands in the Deny column.
  5. Click OK.
  6. If necessary, repeat steps 2-5 for as many object types as you need.
  7. On the 3rd step, assign the Role to Authenticated Users, including the domains where the commands must not be executed in the Assignment Scope of the Role.
by (960 points)
I've tested this solution, but i still see the commands in the web interface. When i click it though, i get "Access is denied".
I've also done a iisreset after applying these rights.
It is a bug in Adaxes that will be fixed by the next release. Custom Commands that a user doesn't have the right to execute on a specific object shouldn't be shown in the Web interface on the page that displays properties of the object.
For now, until the workaround is available, you can create the following workaround:
  1. You can disable all Custom Commands on the Web interface. For information on how to do this, see step 4 in Disallow Certain Operations on Active Directory Objects.
  2. Then, you can create a series of Home Page Actions, one for each Custom Command. For information on how to do this, see section Custom Command in Configure Home Page Actions. On step 3 of the section, you will find information on how to allow objects located in a specific OU or container. Specify the DN of the domain where the Custom Command can be executed as the container DN.
by (960 points)
When will the next release be available? This is very important for the use of the webinterface for our users. Would it be possible to get a fix for this?
The workaround with custom commands as actions on the home page is not a good solution for us.
First of all, you should pay attention that when you execute Custom Commands from AD object lists. In object lists, the Web interface shows all Custom Commands that can be executed on the selected object types, regardless of permissions granted to the user. The permissions are not checked in AD object lists by design because checking permissions would cause a huge performance loss. To workaround this, you can disable Custom Commands in AD object lists. For information on how to do this, see step 6 in the following tutorial: http://www.adaxes.com/tutorials_WebInte ... bjects.htm.
On the page used for viewing properties of an object, permissions are checked. That is, a user will be shown only the Custom Commands they can execute on the object. The issue is that when you disallow executing a Custom Command by assigning a Deny execute permission, the permission is not taken into account when building the list of Custom Commands. However, if you distribute the permissions to execute Custom Commands only with the help of the Allow execute permissions, they will be taken into account when building the list of Custom Commands shown to the user. So, you can workaround the issue by distributing the permissions to execute the Custom Commands with the help of the Allow execute permissions only. To do this:
  1. Check that none of the Security Role give the Execute All Custom Commands permission for the object type (e.g. User). If any Security Roles give such a permission, remove it and add permissions to execute each Custom Command separately.
  2. Create a set of Security Roles, one Role per 'environment'. In that Role, you need to add the Allow permission to execute all Custom Commands that belong to a particular 'environment', assign the Role to Authenticated Users, and include the domains where the Command can be executed in the Assignment Scope of the Role. So, for example, for Citrix Custom Commands, you need to create a Security Role that allows the right to execute all Citrix commands, and include all domains that are running the Citrix platform in the Assignment Scope. To create such a Security Role:
    • Create a new Security Role.
    • On the 2nd step of the Create Security Role wizard, click Add.
    • Select the object type on which the Custom Commands can be executed (e.g. User).
    • In the General permissions section, check the necessary Custom Commands in the Allow column.
    • Click OK.
    • If necessary, repeat steps 2-5 for as many object types as you need.
    • On the 3rd step, assign the Role to Authenticated Users, including the domains where the commands can be executed in the Assignment Scope of the Role.
by (960 points)
Good. This was part of the solution.. The other part was to remove "Full Control" over User objects.. With Full Control enabled, you will still see the command and be able to execute it.
Yes, the Full Control permission also includes the permission to execute all Custom Commands.
I'd like to return the litigation hold attribute values if the script returns true. How can I do this?
asked Aug 26 by GronTron (390 points)
We have a certain amount of licenses. We recently integrated with EntraID and all the objects got auto-licensed. We only want user accounts (no mailboxes/no guests accounts etc) to ... object is created in Entra. Is there any way to specify a rule for this?
asked Apr 2 by tromanko (410 points)
Where can I manage what can be seen on this page including the tabs, and the details of the requests? I don't want the user to see who approved or denied a request.
asked Jan 30 by apruitt (580 points)
