I'm trying to run a powershell script after password reset in order to create a record of the new password in a mysql database. Here is the script I'm using:
## MYSQL Connection
## This requires mysql connector net
## All variables will need changing to suit your environment
$server= "password.domain.org"
$username= "Adaxes"
$password= "P@ssW0rd"
$database= "passworddb"
## The path will need to match the mysql connector you downloaded
[void][system.reflection.Assembly]::LoadFrom("C:\Program Files (x86)\MySQL\MySQL Connector Net 6.8.3\Assemblies\v2.0\MySQL.Data.dll")
$SqlConnection = New-Object Mysql.Data.MySqlClient.MySqlConnection
$SqlConnection.ConnectionString = "server=$server;uid=$username;password=$password;database=$database;pooling=false;Allow Zero Datetime=True;"
$Query = "INSERT INTO userpasswords(username,password,moddate,ip,modbyuser) VALUES('%username%','%unicodePwd%',%datetime%,'Adaxes','%initiator%') ON DUPLICATE KEY UPDATE password='%unicodePwd%',moddate='%datetime%',ip='Adaxes',modbyuser='%initiator%'"
    $SqlConnection.Open()
    $SqlCmd = New-Object MySql.Data.MySqlClient.MySqlCommand $Query, $SqlConnection
    $SqlCmd.ExecuteNonQuery()
    $SqlConnection.Close()
However Adaxes is not putting the new password into the script. Do I have to use something other than unicodePwd? Here is the query that the mySql database receives after Adaxes sends it:
INSERT INTO userpasswords(username,password,moddate,ip,modbyuser) VALUES('test_user','',2/26/2014 3:53:17 PM,'Adaxes','ryan_breneman@domain.org') ON DUPLICATE KEY UPDATE password='',moddate='2/26/2014 3:53:17 PM',ip='Adaxes',modbyuser='ryan_breneman@domain.org'
Thanks for your help!
by (920 points)
Can you send a screenshot of your Business Rule to mour support e-mail (support[at]adaxes.com) or post it here?
by (920 points)
Here is the Business Rule:
(Business Rule Screenshot)
and that calls a custom command that actually houses the powershell script:
(Custom Command Screenshot)
I used a custom command because I want this to run after a password reset as well as a password change, but I didn't see anyway to combine both of those into one business rule.
The reason for the issue is that you execute the script in a separate Custom Command. The %unicodePwd% value reference is resolved only in Business Rules triggered before/after creating a user, resetting a password for a user or updating a user. It won't be resolved in a Custom Command.
You have two ways how you can resolve the issue:
  1. Discard the Custom Command and execute the Run a program or PowerShell script action that runs the script directly in your Business Rules. In this case, you will have two separate scripts, and if you need to make modifications, you'll have to do it twice.
  2. Another option is to save the password to a certain property of the user in the Business Rules. For this purpose, you can use one of Adaxes virtual properties that can store text data, for example, CustomAttributeText1.
    So, in the Business Rules, you can use the Update the User action and save the new password to a certain property before launching the script:
    Then, in the script, you can access the password stored in the virtual property. For example, if you stored the password in the CustomAttributeText1 property, you can access it by using the %adm-CustomAttributeText1% value reference in the script.
    Also, it would be wise to clear the virtual property at the end of the script for security considerations. For this purpose, use the following lines in your code:
     $Context.TargetObject.Put("adm-CustomAttributeText1", $NULL)
by (920 points)
Excellent. I'll probably just put the script in each business rule. After I get it working I won't be making many modifications to it.
Is there a way to open the Reset Password window for a user after creation via a custom command? We don't want to send the password via email and don't want the ... m wondering if there is a command that will open the password reset dialog box after creation.
asked May 22, 2025 by ajmilic (130 points)
It isn't possible to translate the following message displayed during the password reset process: "Unable to set password. Make sure the password doesn't repeat any of ... message is not available in the Common Sign-In web interface UI text configuration.
asked Jul 31 by annatortorella (20 points)
We recently received some pentest results that flagged the password reset workflow as being vulnerable to user enumeration. When a user attempts to reset a password we get ... your email" and require that link to access the security questions/reset workflow?
asked Jun 29 by awooten (100 points)
asked Jan 30, 2025 by farid.r (40 points)
Hi i want to add list of OU's here for help desk to go each OU and find user they want for resetting password , how can i do that? In user creation page i can do ... so help desk user can go inside each OU and look for user they want to reset password for
