Hi again,
It seems that there is a problem with the Blind Users role and the add to group features : i configured a user as he can see only a specific OU through blind users role (everyone with full scope and an exception for this user on the OU).
I can browse for a group through the Web UI and then add a new member, but if i want to use the add to group, i can select the user first but when i click next, the Web UI return "There are no groups to add 'My User' to." (Where My User stands for the real user name obviously).
Am i doing something wrong ?
by (800 points)
It seems that you configured the "Add to Group" action to display groups of specific types (see attachment) and the OU doesn't contain groups of the specified type.
by (800 points)
No, on this page, i have only the radio buuton "Allow the user to select groups" and no checkbox checked.
Another idea ?
It's strange,
We can't reproduce such a problem in our environment.
Lets make sure that I understood your case correctly.
1. You have the following structure in the Active Directory
OU1
-User1
-User2
-UserN
-Group1
-Group2
-GroupN
2. You add the following assignments to the Blind User Role:
  • Everyone over All Objects
  • Exclude User1 over OU1
  1. You sign in as User1 to the Adaxes Web Interface, here you can see all groups when you browse the OU1, but when you select 'Add to Group' action, on the Step 2 you receive the message "There are no groups to add 'User1' to."
by (800 points)
That's it
We have reproduced this problem in our environment, it will be fixed in the next service pack, sorry for inconvenience.
Today we released a new build of Adaxes that fixes this bug.
You can download the new build here.
Thanks for the bug report!
Hi there ! I use the blind users role to hide objects to web operators but it seems that default containers (builtin, computers, users) are always visible, when i use group ... rights to edit these objects, i'd like these to be really hidden. Any clue ?
asked Jul 18, 2011 by sroux (800 points)
Hi, Still struggling with blind user role :-) i found out that i cannot exclude configuration object from the role (this is greyed) so users cannot use "My Approval" "My requests" features Is this normal ? TIA
asked Jul 21, 2011 by sroux (800 points)
asked Jul 1, 2025 by srisingerOMF (20 points)
