We want to workflow approve additions to certain groups, but not deletions from them. When you add a group to a group, is it possible to perform workflow approval for this? Using the "Before Adding a Member to a Group" option does not recognize adding a group to another group. Not sure that we want to use the more general "Before Updating a Group" option.
by (950 points)
Hello Brad,
It does. The group to which a new member is added must be included in the activity scope of your Business Rule. Can you post a screenshot of your Business Rule?
I've attached an example. Thanks for looking at this...
I cannot see any attachments...
Let's try this. I tried to upload a pdf file...
(Business Rule - Group to Group Workflow Example)
Brad,
The Business Rule looks good. I guess the condition isn't met.
  • Please make sure that the Description property of the group CO-Geological-Services doesn't contain 'autopopulated' and doesn't start with '[Delegated]'.
  • Also, please try to add a group to the CO-Geology-Southern group.
  • Or just remove the conditions and try to add a group to the CO-Geological-Services group.
This may be a stupid question but I'm looking to create an approval process for users being added to sensitive AD groups such as the domain admins group. How would I ... to use especially since the condition is based on changes that have not yet happened...
asked Nov 1, 2012 by VTPatsFan (610 points)
Is it possible to craft a Business Rule that would send an email notification only if the request for an action was denied? Thanks
asked Apr 5, 2012 by BradG (950 points)
I have a scheduled task that runs a custom command that itself has multiple custom commands that run in a specific timed order. I would like the scheduler to run that top level ... , but Command B and C will wait for Command A to finish. Is this possible?
asked Jul 23, 2024 by DA-symplr (120 points)
WorkFlow : From Adaxes, how can the Director or Assistant validate the employee’s "Job Title" modification request?
asked Jul 12, 2023 by LucasGrd (40 points)
Do you include options for complex workflows? Such as API or csv/tsv files from ADP and other companies for automated provisioning and de-provisioning users based on their work status?
asked Jul 19, 2022 by gdillenbec (20 points)
3,742 questions
1,391 users
