It appears as though you cannot call a custom command, from within a custom command. is this correct? if so, that is rather limiting as there are many tasks that can share common needs. For instance, all of our teachers need access to a set number of groups and printers, but other user types also need access to the same printers but different network shares. So it would be nice to have a custom rule called 'Printer access for bldg1' and use it in other custom commands. :mrgreen:
by (80 points)
Thank you for the suggestion!
We've added this feature to our TODO list.
In one of the nearest releases we will implement an action called 'Execute Custom Command'.
Thank you.
by (80 points)
That would be fantastic! Thanks.
BTW, we decided to include this feature in the next release.
We've officially released Adaxes 2011.3. This version allows you to execute Custom Commands from Business Rules, Scheduled Tasks, and other Custom Commands.
What's New: http://adaxes.com/info_whats-new.htm
For a custom command, I need to perform some actions, then reboot a computer, then perform some more. How can we handle the reboot so the actions continue once the computer is back up and ready? Thanks
asked May 17, 2022 by jcrook (120 points)
Hi Is there any possibility to add groups to "Operations" Panel, especially custom commands, in the WebGUI on the user like we can ... Custom Commands Offboarding Offboarding Initiation Offboarding Initiation Fasttrack Notifications Update Mobile Contract
asked Jul 30, 2021 by m.car (100 points)
Hi there, i've a custom command with multiple powershell scripts (for clearance reasons). If for example the frist script produces an error i Write an Error but the next ... tried with an simple exit 1; I only Write-Errors on issues. Kind regards, Constantin
asked Jul 23, 2021 by Constey (190 points)
It appears as though you cannot call a custom command, from within a custom command. is this correct? if so, that is rather limiting as there are many tasks that can ... rule called 'Printer access for bldg1' and use it in other custom commands. :mrgreen:
asked Aug 24, 2019 by bradleyrose (50 points)
