I've got the following script as part of a larger piece where param-members is an AD Object picker list seperated by a ' ; ' currently:
New-DistributionGroup -Name 'U_Mailbox - %param-company% %param-mailbox-name%' -Alias '%param-mailbox-name%.group' -DisplayName 'U_Mailbox - $company %param-mailbox-name%' -OrganizationalUnit '%param-company%' -PrimarySMTPAddress '%param-mailbox-name%.group@%param-domain' -members '%param-members%'
The problem is that param-members provides the DN of the User object and I either need that to be in "" or convert that to username but I'm struggling to achieve that with multiple Users selected
by (260 points)
edited by
The parameter value is an array of distinguished names (DNs) separated by the value specified in the parameter settings. As a solution, you can iterate through the DNs, form the required list and then pass it to the -Members parameter. For an example on how to use parameter values in such a way, have a look at Script 1: Add temporary membership of the following article in our repository: https://www.adaxes.com/script-repository/temporary-group-membrship-s533.htm.
Also, to execute the New-DistributionGroup cmdlet, you will need to connect to Exchange. For details, see https://www.adaxes.com/script-repository/connect-to-exchange-with-powershell-s506.htm.
Trying to create a new group and getting the following error: "The name reference is invalid. (Server: example.com)" I've created groups before...the problem seems to have just ... a new Group object. It has me puzzled so I'm looking for some direction...
asked Feb 28, 2014 by RickWaukCo (320 points)
I'm learning the Adaxes powershell methods for creating objects. I would like to create a contact that is mail enabled. I attempted to use the example but it failed ... example of how to create a mail enabled contact with PowerShell using the New-AdmObject?
asked Jul 29, 2020 by ComputerHabit (810 points)
Maybe there is a better way to accomplish this, so I'm open to suggestion. We are in a hybrid setup between onprem and M365. When we create a new user, they are ... command in the previous step, right? If needed, I can provide the full script. Thanks!
asked Nov 2, 2023 by AndrewMeyer (20 points)
I've got the following script so far using the SDK but running into an error: You cannot call a method on a null-valued expression. At line:1 char:1 + ... .BindToObjectByDN("$object.SearchResult.AdsPath.DN") $Context.Items.Add($item, $columnValues) } } } }
asked May 19, 2021 by richarddewis (260 points)
3,737 questions
8,637 comments
550,335 users
