Hi everyone!
I have a problem granting permission to edit group members using the web interface. Somewhere something is missing but I don't see it.
I have three relevant Security Roles:
Self Service adaxes_sr_ss.png Domain Users adaxes_sr_du.png Group Manager adaxes_sr_gm.png
When I log in as a regular domain user with manager role for a group, it is displayed in "My managed objects", but there is no ADD button and I am unable to remove selected users from the group.
So my questions are:
  • Are the Security Role settings correct or is something missing?
  • Once the SRs are correct, what needs to be set in the web interface config for the necessary options to become available?
Thanks for reading!
by (120 points)
Hello Eirik,
Where exactly is the button not displayed? Could you, please, post here or send us (support[at]adaxes.com) a screenshot?
The Security Roles look correct to grant group owners the permissions to modify all properties of the groups they manage.
Could you, please, provide us with all the possible details about the options not being available? Please, post here or send us (support[at]adaxes.com) screenshots of the pages where you expect the options to be displayed.
by (120 points)
Sure, here you go:
This is the ADD button that's missing: adaxes_add.png
And here are the settings for the web interface: adaxes_ui_settings.png
If you need any specific setting not seen here just let me know.
P.S.: I suppose the relevant settings here are under the Management heading and just noticed they were set to User. I will add the Group settings in a minute.
P.P.S.: Here they are: adaxes_gm01.png adaxes_gm02.png adaxes_gm03.png adaxes_gm04.png
Hello Eirik,
Sorry for the confusion, but we are not sure we understand what you mean. According to the screenshot, the ADD button is displayed. Could you, please, provide screenshots for the steps you take to get to the page where the button is not displayed?
by (120 points)
The screenshot is from an administrative user (full Adaxes admin) using the admin web interface , not from the standard user I'm trying to get this to work with. Just for comparison. In both cases I use the user menu to go to My managed objects, then click one group. The admin can edit, the standard user can't.
Hello Eirik,
Thank you for clarifying. It looks like the button is disabled in the Web Interface configuration. To enable it:
  2. In the top left corner, select the Self-Service Web Interface.
  4. In the Forms and Views section, select the Group object type.
  5. Activate the View tab below.
  6. In Sections, select Members.
  7. In Section Configuration on the right, scroll down to Adding/Removing Members.
  9. Same the changes.
  10. Important: Before checking the changes, refresh the Web Interface page using Ctrl+F5.
by (120 points)
Damn, and I thought I had looked everywhere! Thanks a lot. Finding it in View and not in Modify is a bit confusing, though.
Hello, I'm evaluating the use of Adaxes at my organization, where on a weekly basis we have users changing positions, and require (among other things that Adaxes appears to be capable ... are destined to go to, and a date for this action to happen on? Thanks!
asked Dec 2, 2015 by jduketow (50 points)
Hello, I downloaded the latest version of the software but once done the standard setup, it's impossible to access by web interface. The Service is Up and running on port 80. Whats Wrong ?
asked Aug 31, 2011 by Zio (80 points)
We would like users to be able to add their mobile number and carrier information from within the web console. Preferably, they would enter their mobile number in a ... ". This address would then be written to an extensionAttribute field in Active Directory.
asked Mar 2, 2016 by Kikaida (1.1k points)
Running 2014.1 here. Is it possible to expose Exchange "CustomAttributes" (may actually be called "ExtensionAttribute" with Ex2013) for viewing / editing via the Web ... then manually add "extensionAttribute#" for each attribute I want to view / edit.
asked Oct 5, 2014 by bradenmcg (260 points)
Is there a way to create user accounts in bulk via the web interface? Account operators will only have access through the web interface, so this is important.
asked Sep 8, 2011 by abdutal (110 points)
