My role as a developer require a form submission with Adaxes to get JIT (just in time) access to an client environment, I want to need guidance to form submission with the Adaxes PowerShell module.
Here's the screen we fill out and submit for JIT access to an environment, which simply adds my credentials to some JIT AD group for a time window.
Here's my attempt of interacting with the Adaxes PowerShell SDK module with no luck.
Hello Spencer,
Sorry fort the confusion, but we are not sure we understand what the Web Interface form is intended for and what the desired result is. Could you, please, provide all the possible details regarding the desired workflow with live examples?
Here's my workflow:
  1. Log into our adaxes site using my hosting credentials while connected to our hosted VPN
  2. Select one of our hosting clients from a list which comes from this endpoint: /Adaxes/api/SelfService/activeConfiguration/actions)
  3. A modal pops up and has be select from the list of AD groups. This endpoint looks something like this /Adaxes/api/SelfService/listView/dataSources/[GUID]/items
  4. Upon choosing the AD group that I would like to temporarily added to (which I believe does a POST to this /Adaxes/api/SelfService/directoryObjects/valueReferences/resolve), another popup form has me fill out the business purpose of the request, an incident number, and confirm a little check box.
  5. Clicking the submit button runs a PATCH request with something like this /Adaxes/api/SelfService/directoryObjects?key=CN=JIT+Local+Administrator,OU=Just-In-Time+%28JIT%29+Groups,OU=Groups,OU=Hosting,DC=hosting,DC=local and body for this request looks something like this
    "properties":[
          "propertyName":"adm-customattributetext1",
          "propertyType":3,
          "values":[
             "Apply idea hotfix to hcut"
          "propertyName":"adm-customattributetext3",
          "propertyType":3,
          "values":[
             "Task-251524"
          "propertyName":"adm-customattributeboolean2",
          "propertyType":6,
          "values":[
             true
          "propertyName":"adm-customattributetext2",
          "propertyType":3,
          "values":[
             "CN=My Name,OU=Users,OU=Hosting,DC=hosting,DC=local"
  6. I then receive an e-mail confirming that my user has been added to the selected AD group
This is the workflow that I'm trying to automate. So I would love some insight on how I might go about this. Are there way for me to authenticate and get a token and hit some of these same endpoints? Or would that be best suited for the powershell module?
Hello Spencer,
Thank you for clarifying. Unfortunately, there is no such possibility except for using the Web Interface itself. As an option, you can use a PowerShell script. In the script, you will need to manually enter all the property values same as the distinguished name of the group. For examples, you can check section Sample scripts in our SDK: http://adaxes.com/sdk.
Is in Adaxes used (soon deprecated) AzureAD module for managing Azure/ Office 365 somewhere? Or is it using Microsoft Graph SDK module completely?
asked Feb 27, 2023 by KIT (910 points)
I'm seeing this error when I run a user deprovision. It still executes the script but nobody likes errors! Run PowerShell Script 'DuoDeprovisionExport' For the user. The term ' ... running an export script in the first place for my Duo user info. ) Thanks.
asked Feb 19, 2020 by rainamaina (60 points)
is it possible to register new domain with Active Directory Module Cmdlets ? and is it possible to modify/configure password policies with Active Directory Module Cmdlet ? Thx.
asked Apr 22, 2013 by mmichard (360 points)
The individualmodule for PnP if upgraded to 2.2 in non PowerShell 7 breaks in Adaxers. Previous versions of Powershell will not allow the 2.2 PnP version to connect which is ... to make this work but if it is deprecated by MS, then we will lose functionality.
asked Aug 16, 2023 by nick.boehm (20 points)
Are PowerShell commands supposed to show up in the programming interface after adding the module to the Adaxes server? I've installed modules and they don't show.
asked Aug 18, 2020 by ComputerHabit (790 points)
3,365 questions
545,246 users
