The individualmodule for PnP if upgraded to 2.2 in non PowerShell 7 breaks in Adaxers. Previous versions of Powershell will not allow the 2.2 PnP version to connect which is causing errors. We have had to use PnP Module 1.12 to make this work but if it is deprecated by MS, then we will lose functionality.
Hello Nick,
At the moment using PNP.PowerShell module version 1.12 is the only option. Later versions do not work in Adaxes as they require PowerShell 7 which is a separate application not built-in into Windows. We are investigating the possibility of allowing the use of PowerShell 7 in Adaxes which will resolve the issue with the module.
Can you point me to documentation to upgrade from Adaxes 2019.2 ver 3.1.2.174230 to the current version please?
asked Jun 16, 2020 by msylvester (60 points)
Are PowerShell commands supposed to show up in the programming interface after adding the module to the Adaxes server? I've installed modules and they don't show.
asked Aug 18, 2020 by ComputerHabit (790 points)
My role as a developer require a form submission with Adaxes to get JIT (just in time) access to an client environment, I want to need guidance to form submission with the Adaxes PowerShell module.
asked Nov 19, 2020 by spencer.nicol (20 points)
Hi there, we have some custom commands that need the enter-pssession with -sshtransport which is only available in PWSH7. Is it supported to install powershell7 right on the adaxes server? Kind regards, Constantin
asked Mar 3, 2022 by Constey (190 points)
I'm seeing this error when I run a user deprovision. It still executes the script but nobody likes errors! Run PowerShell Script 'DuoDeprovisionExport' For the user. The term ' ... running an export script in the first place for my Duo user info. ) Thanks.
asked Feb 19, 2020 by rainamaina (60 points)
3,351 questions
545,091 users
