The language of Adaxes Web interface and the format used to display dates can be different depending on the signed in user. The language can be selected either automatically or manually, whereas the regional format is always selected automatically.
Language
Each user can manually choose the language of Adaxes Web interface. If a user selects a language manually, the choice is saved in their personal settings and the Web interface is always displayed for them in that language, regardless of the browser and the computer regional settings.
Alternatively, users can let Adaxes automatically select their Web interface language each time they sign in. In this case, Adaxes will select the language based on the list of languages of the user's web browser. If none of the languages from the list match a language Adaxes is available in, English (en-US) will be selected by default. This means that for the same user, a different Web interface language can be selected each time they sign in, depending on the browser language settings.
Regional format
The format for displaying dates is selected based on the Web Interface language. If the language has multiple regional formats e.g. English (United Kingdom) and English (United States), the format is selected based on the language settings set in the user's browser.
For example, if the user selected English as their Web interface language, and English (United Kingdom) is present in their browser language list, the dates will be displayed in the en-GB regional format (DD/MM/YYYY). On the other hand, if the user has English (United States) in their browser language list, the dates will be displayed in the en-US regional format (MM/DD/YYYY). Finally, if the user doesn't have English in their browser language list, the default regional format will be used. For the built-in languages, the default formats are: en-US for English, fr for French, and de for German.
by (630 points)
As you can see in the picture, we currently have three different formats as soon as we look at a user's data. Can this be adjusted so that only one format dd.mm.yyyy is displayed? Thank you very much
asked Nov 17, 2023 by DRiVSSi (360 points)
asked Aug 15, 2025 by cllano (30 points)
Hi, I was just wondering if there was a way to force the format of the date picker value in the web approval interface. We have operation that are very time specific ... like that in the web interface. Example of the problem: Thank you, Jean-Simon Tremblay
asked Dec 3, 2021 by jsimon.tremblay (20 points)
By default, Web Interface URLs look like the following: http://host.company.com/Adaxes/HelpDesk. For the URLs not to contain the Adaxes part: On the computer where Adaxes ... C:\Program Files\Softerra\Adaxes 3\Web Interface by default. Click OK. Restart IIS.
asked Oct 30, 2019 by Adaxes (630 points)
By default, SSL is not configured for the Adaxes Web Interface and network transmissions are not encrypted. However, you can configure SSL on the Adaxes Web ... work in both cases: with Windows-integrated authentication and with forms-based authentication.
asked Oct 14, 2010 by Adaxes (630 points)
