As you can see in the picture, we currently have three different formats as soon as we look at a user's data. Can this be adjusted so that only one format dd.mm.yyyy is displayed?
Thank you very much
by (280 points)
reshown by
by (11.4k points)
Unfortunately, there is no possibility to adjust date formats for certain properties. For information on how date formats are selected for the Web interface, have a look at the Regional format section of the following FAQ article: https://www.adaxes.com/questions/10438/how-are-web-interface-language-and-date-format-selected. Please, note that if the time part of a date/time value is set to 00:00, the time part is not displayed in the Web interface. For example, in the below screenshot, the CustomAttributeDate1 property value is set to November 17, 2023, 00:00 while the CustomAttributeDate2 property value is set to November 17, 2023, 04:07.
Regarding the arrivalDate property, it looks like it is a string property, not a date/time one. As such, the date/time format is not applied to it.
Okei thanks a lot
The language of Adaxes Web interface and the format used to display dates can be different depending on the signed in user. The language can be selected either automatically or ... default formats are: en-US for English, fr for French, and de for German.
asked Feb 10, 2021 by Adaxes (550 points)
Hi, I was just wondering if there was a way to force the format of the date picker value in the web approval interface. We have operation that are very time specific ... like that in the web interface. Example of the problem: Thank you, Jean-Simon Tremblay
asked Dec 3, 2021 by jsimon.tremblay (20 points)
I realise that this has been asked a few times but I can't seem to get to resolution having read through previous advice. We have scheduled tasks set up to automatically ... /time region settings on all servers currently using Adaxes. They're all set to UK.
asked Apr 21, 2023 by Homelander90 (330 points)
I think this started happening back in August when we updated to the current version (3.13.18.106.0). We are not sure though because this only affects the web page ... We would prefer not to allow access through a firewall for this. Screenshot of the error:
asked Nov 23, 2020 by mark.it.admin (2.3k points)
Hi, Following an update from Adaxes 2016 to 2021.1 we noticed that the date format on the email notifications is no longer English UK, but English US, i.e. ... every scheduled task/business rule that sends a notification and changing the variable? Thanks, Gary
asked Sep 27, 2022 by gazoco (490 points)
3,355 questions
7,799 comments
545,162 users
