Topic question, we are looking into AD Auditing and I would like to know if this solution is on-prem. And I would like to know if there is a built in report to see ALL changes in AD within a time frame as well as see changes that occur after hours. We have been using the free version of Netwrix and I can see when someone tries to access folders they do not have permissions to, is this something I can do with Adaxes?
by (11.8k points)
Yes, Adaxes is an on-premises AD Management software and can be installed on a domain-joined computer.
Adaxes logs only the operations performed via the software itself. Operations performed outside of Adaxes (e.g. using Active Directory Users and Computers) are not logged.
Unfortunately, there is not such possibility. Adaxes only logs AD related operations such as logins, user updates, etc. Other operations (e.g. accessing folders on the file system, network activity) are not logged and cannot be viewed in Adaxes.
Thank you for the quick responce.
We use this date to determin transfers and start dates. Basicaly on this day the Adaxes resets the password. In the report I would like to ... name, first name, last name, employeeID, CustomAttributeboolean1, customattributeboolean2, and customattributedate2.
asked May 17, 2023 by mightycabal (1.0k points)
I had a script that would copy the values from adm-CustomAttributeTextMultiValue1 and save them into extensionAttribute15 as a comma seperated list. The script somehow got deleted and I can't seem to find the tutorial I used to create it before.
asked Jul 1, 2022 by jordan (110 points)
3,365 questions
545,297 users
