Unfortunately, there is no easy way to do such a thing. As an option, you can try using a custom command to allow users perform access requests. For example, you can use a parameter with predefined folder paths and the following script from our repository: https://www.adaxes.com/script-repository/change-permissions-for-sharepoint-folder-s202.htm. Users will select a predefined folder, the script execution will be submitted for approval and once approval is granted, the permissions will be delegated.
Do you have any video examples or tutorials of this working with Sharepoint online?
Unfortunately, there is no such thing as Adaxes does not have UI for it. We only have scripts in our repository.
Here we use BambooHR but we only have the conection thrue a group in AD with SML in BambooHR, so can we have a conection way thrue ADAXES to change setings, Examle Manager, Departament etc...
asked Jun 7, 2022 by abisaigomezm (40 points)
We have users with group memberships in multiple domain. All groups are type Universal. For example we have DOMAIN A and child domains for each dept, such as ... group memberships during user account copy, including memberships from other domains? Thank you,
asked Sep 10, 2020 by maliguinem (20 points)
Like remove all users from full access other than User1, User 2, & User3?
asked Oct 29, 2019 by hgletifer (1.3k points)
We are working with an HR package that will send us a CSV file every 4 hours with a list of users that need to be created, modified or deleted from our environment. The CSV ... change, etc.) Is there a script that can manage all of that on a scheduled basis?
asked Sep 2, 2020 by RayBilyk (230 points)
3,355 questions
7,799 comments
545,152 users
