Is it possible to retrieve the first letter of first names (double name).
example:
Jean-Francois -> jf
thx
by (360 points)
Try this one:
%firstname,1%%lastname,1%
To edit a value reference, right click it in the edit box and select Edit Value Reference.
I do not understand.
In fact, I do this:
You can do this with the help of a PowerShell script.
For more details, please see Validate/Modify User Input Using a Script.
Hello, is it possible to put the first letter of the name in uppercase: example: Marc thx
asked Feb 14, 2013 by mmichard (360 points)
Good Morning, I'm trying to think of a way to set the username of some of our users who have multiple first and last names. For example, Juan Carlos De Vega. The first ... very first name and last 7 of the very last name? Any help would be appreciated! Thanks
asked Dec 28, 2017 by jhair (520 points)
I'd like to know how many versions of Adaxes are there with the patches/updates of every version and how often do they receive the updates. In addition of how often the major upgrades occur?
asked Jan 16 by farid.r (20 points)
If the user name submitted is "jhon doe" all of the users properties will be lower case. We want it to force it to be "Jhon Doe" even if it was submitted in lower case.
asked Aug 31, 2022 by raul.ramirez (210 points)
Hello I have two questions about date field in the the web GUI. Is it possible to determine the first day of the week? In my case Monday should be the first day of ... allow change time". I have not found this in the web configurator. thx & regards pudong
asked Jul 8, 2022 by pudong (670 points)
545,382 users
