is it possible to put the first letter of the name in uppercase:
example: Marc
thx
by (360 points)
Yes, this is possible. When would you like to check the user's name: before creation, after creation, may be after modification or on a scheduled basis? Could you provide some more detail on what you are trying to achieve?
i will like check the user's name before creation with user pattern.
This cannot be done with Property Patterns, but you can use a Business Rule for this purpose. You can create a Business Rule that will be launched before creating a user and that will always set the first letter of the user's name in upper case. See the Validate/Modify User Input Using a Script Tutorial for instructions on how to create such a Business Rule. On the 5th step of the tutorial, you need to paste the following script:
$firstName = "%givenName%"
$firstName = "%givenName:upper,1%" + $firstName.Substring(1)
$Context.SetModifiedPropertyValue("givenName", $firstName)
If you would also like to set the first letter of the user's surname in uppercase, add the following lines to the end of the script:
$lastName = "%sn%"
$lastName = "%sn:upper,1%" + $lastName.Substring(1)
$Context.SetModifiedPropertyValue("sn", $lastName)
I tried your script I am receiving an exception calling "SetModifiedPropertyValue" with"2" arguments: property can't be modified in this context because no action is available
The scripts will work only in a Business Rules triggered before creating or updating a user. They won't work in Custom Commands or Scheduled Tasks. If you want to use them in commands or tasks, you'll need slightly different versions of the scripts.
First Name:
if ($firstName -cne "%givenName%")
    $Context.TargetObject.Put("givenName", $firstName)
    $Context.TargetObject.SetInfoEx(@("givenName"))
Last Name
$lastName = "%sn%"
if ($lastName -cne "%sn%")
    $Context.TargetObject.Put("sn", $lastName)
    $Context.TargetObject.SetInfoEx(@("sn"))
Hello, this works very well for me, but, if there are two surnames, how do I capitalize them both?
Example: Vincent Van Gogh
Is it possible to retrieve the first letter of first names (double name). example: Jean-Francois -> jf thx
asked Dec 12, 2011 by mmichard (360 points)
Hi there, Adaxes looks great. It needs a bit of time to investigate all the features. I wonder how to upper lastname in a property pattern, to enforce strict naming convention. Any clue ? Thanks in advance
asked Mar 17, 2011 by sroux (800 points)
Here are the actrions of the custom command. Here are the parameters. Need a script to copy the param user's file path for home drive example: Param user's home drive ... ) should be //server1/homedirs/%username%. Then give the user full control of the folder.
asked Feb 8, 2023 by mightycabal (1.0k points)
Hello The danish/norwegian letter "Ø" is not handled correctly in Adaxes. Even if regexp is set to ^[A-Z] , it's still possible for the user to enter and use the letter "Ø" in their ... : - "Ø" = U+00d8 (upper case) - "ø" = U+00f8 (lower case) - Thanks
asked May 11, 2016 by Boxx.dk (2.6k points)
Hello, Currently we are using the script from another topic to add a number to the username counting up until it finds a unique name. However, we need the username to still ... changed to " + $userLogonName ` + ".", "Information") Thanks for the assistance.
asked Feb 9, 2016 by jhair (520 points)
7,805 comments
545,181 users
