I've setup an Business Rule with trigger after creating user object. I deal inside with multiple types of objects (Employee-, Shared Mailbox-, Admin-Accounts,..), where a different set of custom commands are executed. How can i manage it to prove if custom command "A" was successfully processed before execute next custom command "B" and so on...
Here and screenshot about my current config. BR after creating user example.png
thank a lot in advanced
best regards R.Aich
Hello Robert,
Unfortunately, there is no possibility to check whether an action (e. g. execute custom command) was successful before executing the next one. All actions are performed one after another no matter of the actual results. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
HI *, I would kindly ask if there is a way to pass value to running custom script trough web interface. I see some old discussions on the forum that this feature should be come ... I cannot find it. Could you please help me to find out how to proceed? Thanks.
asked Jan 26, 2015 by majin (50 points)
asked Oct 18, 2022 by lw.fa (130 points)
I've modified the script here https://www.adaxes.com/script-repository/import-users-to-be-deprovisioned-s3.htm to do bulk deprovisioning of accounts via a .csv file. It ... share and folder. Why is this throwing this error? They path works in file explorer.
asked Mar 26, 2021 by johnsonua (390 points)
Dear Support, is it possible to run external applications, for example "Star-Process cmd.exe ... " via initiator account, not service one? For example to implement a ... object, so that cmd windows opens on the initiators workstation. Thank you for advise!
asked Sep 27, 2019 by Dmytro.Rudyi (920 points)
I have a custom command that is invoked by a business rule. I need to temporarily disable this custom command from running, however in testing I see that even though the custom command is disabled it is still executing. Is this normal?
asked Mar 29, 2016 by lasership (370 points)
7,805 comments
545,177 users
