Dear Support,
is it possible to run external applications, for example "Star-Process cmd.exe ... " via initiator account, not service one?
For example to implement a custom command to ping computer object, so that cmd windows opens on the initiators workstation.
Thank you for advise!
by (920 points)
Hello Dmytro,
That's too bad :(
Thanks for the quick reply!
Hello, I've setup an Business Rule with trigger after creating user object. I deal inside with multiple types of objects (Employee-, Shared Mailbox-, Admin-Accounts,..), ... and screenshot about my current config. thank a lot in advanced best regards R.Aich
asked May 16, 2022 by R.Aich (20 points)
I've modified the script here https://www.adaxes.com/script-repository/import-users-to-be-deprovisioned-s3.htm to do bulk deprovisioning of accounts via a .csv file. It ... share and folder. Why is this throwing this error? They path works in file explorer.
asked Mar 26, 2021 by johnsonua (390 points)
I have a custom command that is invoked by a business rule. I need to temporarily disable this custom command from running, however in testing I see that even though the custom command is disabled it is still executing. Is this normal?
asked Mar 29, 2016 by lasership (370 points)
So if i want to run an external program and use a script i would put - cscript.exe registerUser.vbs ... but where should this script be saved to for adaxes to pick it up?
asked Mar 14, 2018 by ScottGriff (400 points)
Hi, When we add custom command action in UI, when a user selects 1 or more users for that custom commands, is there a way to integrate those selected users as input value into that custom command script and take action on those users.
asked Feb 5 by Renugopal (120 points)
7,805 comments
545,177 users
