The checkbox is not selected (False) by default.
by (70 points)
by (304k points)
Hello John,
It can be done using a property pattern. For an example, have a look at the following tutorial: https://www.adaxes.com/tutorials_SimplifyingDataEntry_AutomaticallySetAccountExpirationDateForNewUsers.htm. In your case, on step 3 select the custom Boolean attribute you need.
I am trying to see if I can implement this in Adaxes somehow to support role-based provisioning to external apps (using appropriate Powershell scripts) but struggling to work ... to invest in a full-blown role-based provisioning platform (would rather not!).
asked Dec 24, 2019 by Bernie (310 points)
asked Apr 14, 2023 by mightycabal (1.1k points)
Hi, In the SDK I find information on how to use Powershell to read and create scripts in custom commands and business rules, but I can not find the same for ... information like the embedded scripts for the report and custom columns? -- Morten A. Steien
asked Jul 27, 2023 by Morten A. Steien (300 points)
3,717 questions
8,592 comments
549,984 users
