In the SDK I find information on how to use Powershell to read and create scripts in custom commands and business rules, but I can not find the same for reports.
How can I access the report configuration objects to extract information like the embedded scripts for the report and custom columns?
-- Morten A. Steien
by (300 points)
Hello Morten,
Sorry for the confusion, but we are not sure we understand what exactly you are trying to achieve. Please, describe the desired workflow in all the possible details with live examples.
For Custom Commands it is documented in the SDK here: https://www.adaxes.com/sdk/DefiningActionsAndConditions/ The Managing Reports section do not have similar information (that I can find ).
This is (the relevant part of) the script that I use for Custom Commands to save the script(s) to a file. I need to make a similar script for Reports
$ActionTypes = ("Conditions", "Actions", "ElseIfConditionedActions", "ElseActions")
foreach ($ActionType in $ActionTypes) {
  foreach ($Action in $ActionSet.$ActionType) {
    $NotFound = $true
    if ($Action.Class -eq "adm-ScriptCondition") {
      $ActionCommand = $Action.GetCondition()
      $NotFound = $false
    if ($Action.Class -eq "adm-RunScriptAction") {
      $ActionCommand = $Action.GetAction()
      $NotFound = $false
    if ($NotFound) { continue }
    $ScriptContent = $ActionCommand.Script
    $ScriptContent | Out-File -FilePath ($BaseDirectory + "$ScriptName`.ps1") -Encoding utf8
Hello Morten,
Thank you for clarifying. You need to bind to the report and then use the corresponding properties to obtain the script used to generate the report. The script will look like below. You can check section API documentation\ADSI provider\Reports of our SDK for details.
$reportDN = "CN=My Report,CN=Reports,CN=Reports Root,CN=Configuration Objects,CN=Adaxes Configuration,CN=Adaxes" # TODO: modify me
# Connect to Adaxes service
$ns = New-Object "Softerra.Adaxes.Adsi.AdmNamespace"
# Get report generator
$report = $service.OpenObject("Adaxes://$reportDN", $null, $null, 0)
$reportConfig = $report.GetConfiguration()
# Get report script
 $reportScript = $reportConfig.Generator.Script
Perfect! Thank you for your excellent help. :)
I'm in the process of creating a Web interface for requesting IT accounts. Upon submission, I want to run a Powershell script that will create an item in a Sharepoint task list.
asked May 14, 2021 by sandramnc (870 points)
I added the Password last set field to the Admin view but when I click on edit it allows the admin user to change the value. Adaxes correclty handel Bad Password time and Bad password ... last set, so I guest there is a way but I can not find it. Thanks you
asked Dec 19, 2019 by tomlaf (60 points)
The checkbox is not selected (False) by default.
asked May 30, 2022 by john.harding (70 points)
asked Jan 17, 2023 by stevehalvorson (110 points)
3,354 questions
7,795 comments
545,124 users
