Here we use BambooHR but we only have the conection thrue a group in AD with SML in BambooHR, so can we have a conection way thrue ADAXES to change setings, Examle Manager, Departament etc...
by (40 points)
Out of the box, Adaxes does not integrate with any third-party software. However, if the software has an API, it should be possible to send requests to it from Adaxes using scripts. Similarly, if the software has such a feature, it should be able to send requests to Adaxes using scripts or the REST API. Unfortunately, we were no able to find any documentation on BambooHR API. However, you can check with their support team.
by (60 points)
I believe you should integrate BambooHR into Azure AD, since ADAXES is managing/maintaining the AD. ADAXES will 'see' the changes made and if you make change through ADAXES, BambooHR should 'see' this as well.
After all, the Active Directory is the heart of your infrastructure. Just keeping it simple...
This would seem like an easy setting since right now, it's causing so much logs because on the main screen, I have a few reports that are custom made and everytime a user ... . Below is a screenshot example of hoe it constantly can fill up the log. Thank You!
asked Jul 31, 2023 by Edogstraus00 (590 points)
When I create a user from adaxes I also want it to be added to MS Teams groups. At this moment i create the account in adaxes after that i need to add this user in all groups that we have in MS Teams so i what to automate this when i create a new usuer.
asked Mar 29, 2022 by abisaigomezm (40 points)
