based on this article How to create Resource Mailboxes a few slide modifications aside we are currently creating resource and equipment mailboxes in our on-premise environment.
Now we are going to switch to O365, which our Adaxes installation is already prepared for and set up. My question at this point in time is, how do a transfer our existing processes / scripts from using on-premise to O365. Does this work at all?
Appreciate your input.
Kind Regards
Ingemar
by (960 points)
Support, are you there?
Hello Ingemar,
Sorry for a delayed reply.
Yes, it is possible. Check the following script in our repository that shows how to convert user mailboxes to resource mailboxes in Exchange Online: http://www.adaxes.com/script-repository ... e-s160.htm.
Hi there. I'm trying to work out the best way to create a shared mailbox, which will automatically create a group based on the shared mailbox name, and then add ... the delegation of the shared mailbox. Any advice/scripts etc will be much appreciated. Thanks
asked Aug 27, 2014 by ColinB (180 points)
We have internal AD that syncs to o365 via Azure AD Connect. It is not a hybrid environment; there is no Exchange on site. I am trying to find the best way to use Adaxes to ... so I am not sure the best way to handle that. Thanks for any help you can provide.
asked Apr 15, 2020 by Jasonmh (540 points)
Hey Guys We have some issues with new meeting rooms that we have created. Previously we used to have on-premise exchange but switched to office365. Before doing ... OU but the interface are different. under exchange properties they are different aswell.
asked Sep 18, 2019 by seanr (70 points)
In Adaxes 2021, it appears you can edit Exchange Online calendar permissions for users and shared mailboxes, but not resource mailboxes. Considering resource mailboxes are often used ... purposes, why have they been excluded? Is there a way to include them?
asked Jan 5, 2023 by tjackson111 (60 points)
7,805 comments
545,196 users
