In Adaxes 2021, it appears you can edit Exchange Online calendar permissions for users and shared mailboxes, but not resource mailboxes. Considering resource mailboxes are often used for scheduling purposes, why have they been excluded? Is there a way to include them?
by (60 points)
Currently, Microsoft Exchange does not provide UI for managing calendar permissions. We did it specifically in Adaxes for users to have a comfortable way of controlling the permissions. We will consider adding the functionality for resource mailboxes in future releases. As of now, the permissions can only be set using PowerShell scripts.
Hi there. I'm trying to work out the best way to create a shared mailbox, which will automatically create a group based on the shared mailbox name, and then add ... the delegation of the shared mailbox. Any advice/scripts etc will be much appreciated. Thanks
asked Aug 27, 2014 by ColinB (180 points)
asked Jul 22, 2021 by jtop (680 points)
From my understanding I need to use a script to add send as and delegated mailbox permissions for 365 mailboxes. Does anyone have a sample script I could use for reference? Please and thank you!
asked Sep 25, 2018 by john.morrow (270 points)
Hi, based on this article How to create Resource Mailboxes a few slide modifications aside we are currently creating resource and equipment mailboxes in our on-premise environment. ... to O365. Does this work at all? Appreciate your input. Kind Regards Ingemar
asked Oct 26, 2016 by ijacob (960 points)
Hello, we want to set calendar permissions for members of a distribution list. The mailbox on which the permissions must be set is specified, no variable. Example: Members of ... how to set this permissions, can you point me in the right direction? Thanks.
asked Sep 30, 2020 by lohnag (160 points)
3,365 questions
545,251 users
