I have created a Custom action to create some "standard" sub OUs to a particular type of OU in our AD. I wanted to create a script to look in the OU you are executing against and not run again if ANY of the sub OUs exist. I want something like below but I am not sure how to get $OU to have the appropriate collection.
foreach ($child in $ou)
if(($child.Name -eq 'Groups') -or ($child.Name -eq 'Users') -or ($child.Name -eq 'Computer Systems'))
{$Context.ConditionIsMet = $False }
by (300 points)
Is there a way to have a Scheduled Task with 4 different condition? I want to create a scheduled task start every Monday and the condition see: The next Saturday of the week ... of the week is the fifth of the month then no action Thanks in advance, Simone
asked Jan 18, 2022 by Simone.Vailati (430 points)
Hi, In the SDK I find information on how to use Powershell to read and create scripts in custom commands and business rules, but I can not find the same for ... information like the embedded scripts for the report and custom columns? -- Morten A. Steien
asked Jul 27, 2023 by Morten A. Steien (300 points)
I'm in the process of creating a Web interface for requesting IT accounts. Upon submission, I want to run a Powershell script that will create an item in a Sharepoint task list.
asked May 14, 2021 by sandramnc (870 points)
I have an account that I am using as the "run as" account to run PowerShell scripts for several different custom commands. I would like to be able to update the ... a script that updates the credentials used to run a script in an existing custom command?
asked Oct 18, 2021 by KelseaIT (320 points)
3,372 questions
545,359 users
