Hi, I need business rule that will forbid changing group membership type to rule-based for selected groups.
Additionally I need PowerShell script for adding more groups to be watched by this rule.
Thanks in advance!
by (910 points)
Do we understand correctly that you have groups set as rule-based and want to prohibit anybody from changing the type to assigned? If that is correct, you can use a business rule like below. image.png Pay attention that the Activity Scope should include the groups themselves, not their members.
For information on how to update the Activity Scope of a business rule using scripts, have a look at the following SDK article: https://adaxes.com/sdk/DefiningScopeOfActivity.
To be more specific I want to forbid adding rule-based groups to specific group(s). But at the same time I need to forbid changing already added groups (even nested ones!) to rule-based group. So I assume I will have to use something like image.png But I am unsure what should goes to the right side of the equals operator?
And then scope this rule to group and its members (so even nested groups cannot be rule-based)? image.png
+1
In this case, you need to use a business rule like the following: image.png In the condition, use the below script:
# Get member group type
if ("%adm-MemberObjectType%" -eq "group")
    $memberGroupType = $member.MembershipType
$Context.ConditionIsMet = $memberGroupType -eq 1
There is no need to do anything about that. It is not possible to add members to rule-based groups manually. They will only be added automatically based on the rules you specify.
Perfect!
Rule-based membership fails for security enabled distribution group with error "The term 'Add-DistributionGroupMember' is not recognized as the name of a cmdlet, function, ... Exchange Online before running this PowerShell command. Here is rule based set up.
asked Mar 7, 2023 by KIT (910 points)
I have a Rule-Based group with users. Every time a users gets added or removed from this group I want to trigger a Business Rule for "Atter adding or removing a member ... Rules be triggered by a Rule-Based group adding or removing a user? Morten A. Steien
asked Mar 27, 2023 by Morten A. Steien (300 points)
Hi, I need same functionality as is rule-base membership for AD groups, but for AAD groups. To be more specific, I want to have AAD group that contains all user members from all selected groups (even nested ones!)
asked Mar 6, 2023 by KIT (910 points)
We would like to be able to, possibly through a script or report, search for attributes that equal specific values and find all rule-based groups that used those rules. An ... and being able to list all rule-based groups that use that in their query set.
asked Oct 5, 2022 by wesmcmillan (20 points)
3,365 questions
545,291 users
