I have several windows powershell scripts that work perfectly with AD- however, I can not get these to run as an Adaxes script (Scheduled Task)
It is very simple, as I include below. Any help would be most appreciated, as I will not always be available to run these reports monthly.
$dist = ForEach ($group in (Get-DistributionGroup -Filter {name -like "*project distribution list"}))
       {  Get-DistributionGroupMember $group | Select @{Label="Group";Expression={$Group.Name}},@{Label="User";Expression={$_.Name}},PrimarySMTPAddress
    $dist | Sort Group,User | Export-CSV PDL-Members1.csv -NoTypeInformation
# Rename-Item -Path PDL-Members.csv -NewName PDL-Members_Con1_$(Get-Date -f yyyy_MM_dd).csv
by (70 points)
Can you post the error messages and/or warnings that you get? Also, is it the complete script or only a part of it?
Hi support,
This is the complete script from adaxes, have tried to break it down to a single group name to extract members details - so there are commented sections included as well. The activity history show blank ...
Alex
$filePath = 'd:\adaxes\pdl-mbrs.csv'
Import-Module Adaxes
$identity =  Get-AdmGroup "983pdl" # sAMAccountName
$members = Get-AdmGroupMember -Identity $identity -AdaxesService localhost
foreach ($member in $members)
 $dist = $member.Name
$dist | Export-CSV $filepath -NoTypeInformation
# $members | Export-CSV d:\adaxes\imbrs.csv -NoTypeInformation
( $members = Get-AdmGroupMember -Identity $identity ) # -AdaxesService localhost )
$dist = foreach ($member in $members)
  #  Write-Host $member.Name
$dist | Sort Group,User | Export-CSV $filepath -NoTypeInformation
$identity = "SalesGroup" # sAMAccountName
# $identity = "CN=SalesGroup,CN=Users,DC=domain,DC=com" # DN
# $identity = "{EB5FEB21-E648-42AD-B86C-89D3C6807953}" # GUID
# $identity = "S-1-5-21-573937-2149998-410785" # SID
$members = Get-AdmGroupMember -Identity $identity -Server "domain.com" `
#Import-Module Adaxes
#$filePath = 'd:\adaxes\test.csv'
#$groups = (Get-AdmGroup -Filter {name -like "*Project Distribution List"} | Select-Object -Property DistinguishedName)
#$Grp = Get-ADGroupMember -Identity $groups | Where {$_.ObjectClass -eq 'user'} |Get-ADUser -Properties Title,Department|Select Name,Title,Department,SamAccountName,DistinguishedName
#$Grp | Export-CSV -Path d:\adaxes\test1.csv -NoTypeInformation
# ForEach ($grp in $groups)
#        $dist = (Get-AdmGroupMember $grp | Select-Object -Property Name)
#dist$ = Get-ADGroupMember -Identity "CN=970 - Hazelhurst Court - Project Distribution List,OU=Distribution Lists PF,OU=IT,OU=Holdings,DC=Rydon,DC=Group" -Recursive
#       Get-DistributionGroupMember $group | Select @{Label="Group";Expression={$Group.Name}},@{Label="User";Expression={$_.Name}},PrimarySMTPAddress
# DistinguishedName
#$groups | Export-CSV d:\adaxes\groups.csv -NoTypeInformation
#$grp | Export-CSV d:\adaxes\grp.csv -NoTypeInformation
asked Jan 27, 2023 by samuel.anim-addo (20 points)
When running a PowerShell script as an action in a custom command, you can set the script to run as a different account and then use the RunAs property in the ... Is there another way to get the Adaxes service account's credentials from within the script?
asked Mar 31, 2022 by KelseaIT (320 points)
I am having an issue running a powershell script through Adaxes. I am trying to have this run as a business rule when ... $optoffice.DisabledServicePlans = "ONEDRIVESTANDARD" Set-MsolUserLicense -UserPrincipalName %userPrincipalName% -LicenseOptions $optOffice
asked Mar 2, 2015 by malsobrook (50 points)
Receive "Index operation failed; the array index evaluated to null. Stack trace: at &lt;ScriptBlock&gt;, &lt;No file&gt;: line 104&gt;" and "Index operation failed; the ... $GroupName, $GroupDN." } } #foreach write-output "" Write-Output "" Stop-Transcript
3,362 questions
7,812 comments
545,232 users
