Hello Samuel,
Yes, it is possible. For example, you can use a scheduled task like the following: image.png
Hi All, I am looking for a script i can use in adaxes, that removes all delegates for an exchange O365 mailbox, and reset their MFA tokens as well. I ... ($mailbox.Identity)" } } } # Disconnect from Exchange Online Disconnect-ExchangeOnline -Confirm:$false
asked Apr 18 by Brobertson92594 (20 points)
When running a PowerShell script as an action in a custom command, you can set the script to run as a different account and then use the RunAs property in the ... Is there another way to get the Adaxes service account's credentials from within the script?
asked Mar 31, 2022 by KelseaIT (320 points)
Is it possible to add multiple members to a group in a singe call to the REST API? The example code only shows a single member. What would the data structure look like in that case?
asked Dec 13, 2021 by swengr59 (60 points)
7,802 comments
545,176 users
