I changed the view for user -> view and would like to copy those sections to modify ... but I cant find any option? Only copy it to other web interfaces?
by (1.1k points)
Unfortunately, there is no such possibility. The settings can only be configured manually. However, thank you for the suggestion. We forwarded it to the corresponding department for consideration.
Yes, that is correct.
Short Version: Issue: Found that the form\view config under /AdaxesConfig does not match what is seen on the user modify page Long version: We upgraded from 2017.1 to 2018 ... when editing a user are configured for the View Form for User in the /HelpDesk page
asked Sep 4, 2018 by jiambor (1.2k points)
good day, is there any chance to modify the behavior of the address field? Which displays a users address like this: We would like to have City and Zip/Postalcode comma ... question, can the blank line be removed from a drop down list? Regards Ingemar Jacob
asked Sep 16, 2013 by ijacob (960 points)
In AdaxesConfig>Management>Forms and Views>User form - We want the ability to for Department field, when we click Configure to look similar to Manager (when it is configure is ... . I wanted to add some screenshots but didn't see the option to do it.
asked Feb 17, 2023 by mchaudh (40 points)
Whilst the Web UI's Custom Forms and Views for each Object Type is useful, it's also very limiting presentation-wise if we want different users, computers, ... user groups and ensure a tidier experience whilst enforcing ACLs on various attributes and objects.
I am using this script modified for my testing. Import-Module Adaxes $csvFilePath = "D:\TestFeed\ImportNewUsers.csv" # Path to pick up feed file $userIdColumn = "Employee Number" # TODO: ... initial. I would like to add a 2 for now if the sam isn't unique.
asked Oct 17, 2022 by mightycabal (1.0k points)
7,806 comments
545,206 users
